NetPower16 P - Enough power with 96W
I was hoping to use this device for events. But how many Aps Would I actually be able to do with this? is 96Watts Enough. What if I wanted to actually use all 16 ports on this device. Is that possible. to Get 30Watts per port? or even 15?
Why don’t you do the math? Product brochure has some data about PoE out capacity (e.g. 2.8 A (1.4 A per 8port group, max 0.6 A per port) for 30+V). If you go for 54V PA, this means max 32W per port (minus losses on UTP cable towards AP). Etc.
Would this switch fall into CRS3X series of switches that support Bridge Hardware Offloading. I know the articles says CRS3XX series of switches but I didnt see it mentioned in the models section of that page.
Yes, look at the different docs for CRS318-16P-2S+. That is the full model number.
