Was abit bored in the weekend and wrote a script that publish the netwatch status on a web page.
Needed:
-webserver with php and mysql
-ros 3.16 (Works on earlier versions too, but I used that version…)
Please note that I have not taken any action to secure this scripts, so dont publish them on external webservers ![]()
The netwatch code for up :
/tool fetch mode=http address=www.yourpage.no src-path=("/net_status.php?router=1&status=1&time=".[/system clock get time]."%20".[/system clock get date]) dst-path="/netwatch" port=80 host=www.yourpage.no
The netwatch code for down :
/tool fetch mode=http address=www.yourpage.no src-path=("/net_status.php?router=1&status=2&time=".[/system clock get time]."%20".[/system clock get date]) dst-path="/netwatch" port=80 host=www.yourpage.no
Note the following php string options :
router=1 <-its the id of the router in the database- (you have to change this value in the up/down script based on the id of the router in the database, if you dont, it will only update data for 1 router)
status=1 (or 2) <-status 1 means router is up, status 2 means router is down
time ← time and date for action
databasesetup :
Make a database called ‘netwatch’ and a table called ‘netwatch’
Make the following fields : id (Int,auto,index), name (varchar), status (int), time (varchar)
Now insert a couple of routers in the database, you only have to fill in the ‘name’ field, the others will be filled later automatically.
The database connection script: (databaseconfig.php)
<?php
$conn = mysql_connect("localhost", "username", "password") or die(mysql_error());
$db=mysql_select_db("netwatch") or die(mysql_error());
php script for accepting values: (net_status.php)
<?php
* @author bent ole fosse
include "databaseconfig.php";
//get data from header
$router=$_GET['router'];
$status=$_GET['status'];
$time=$_GET['time'];
$query="UPDATE netwatch SET status='".$status."', time='".$time."' WHERE id='".$router."'";
$result=mysql_query($query)or die(mysql_error());
echo "done";
Script for publishing values on a page: (display.php)
<?php
$query="SELECT * FROM netwatch";
$num=mysql_numrows($result);
echo "<table width=800>";
echo "<tr><td align=left>Router</td><td>Time</td><td>Status</td></tr>";
echo "<tr><td align=left>";
for ($i=0; $i<$num; $i++)
if (mysql_result($result,$i,"status")=="1")
echo "<font color=#04B404>".mysql_result($result,$i,"name")."</font><br>";
}else{
echo "<font color=#FF0000>".mysql_result($result,$i,"name")."</font><br>";
echo "</td><td>";
echo "<font color=#04B404>".mysql_result($result,$i,"time")."</font><br>";
}else{
echo "<font color=#FF0000>".mysql_result($result,$i,"time")."</font><br>";
echo "</td><td>";
echo "<font color=#04B404>Up</font><br>";
}else{
echo "<font color=#FF0000>Down</font><br>";
echo "</td></tr>";
echo "<tr><td colspan=3><center>Hopefully this works ok...</center></td></tr>";
echo "</table>";
