Hi, I have a doubt that I would answer as soon as possible.
Intel Quad Port Server Adapter Ethernet I340 T4 system for X, the network’s target has support for mikrotik 5.5?
I340-T4 IBM Gigabit Ethernet Card - PCI Express x4 Network Adapters 49Y4240 - Wired support?
Get a demo license, plug it in, and check it out. IF it doesn’t send - supout.rif to Mikrotik, they will look up precise ID of device and add drivers from Linux Kernel (if there are any) - worked for me every time.
Thanks,![]()
did it work? I was thinking of buying this card.
