I have the following question.
I have a RB951G-2HnD, with actual software 6.45.3. It is configured as an access point as following.
The first ethernet interface is connected to the local (wired) network 192.168.20.x. Through this interface the RB951G is also connected to the internet.
The wireless interface is connected to the first ethernet interface via NAT. The wireless interface is also connected to the RouterOS’s internal DHCP server, which gives the IP addresses to the wireless clients; the network is 192.168.60.x.
The problem: ideally, I would like to connect from every host on a wired network (192.168.20.x) to any host on the wireless network (192.168.60.x). it works perfectly in another direction, but I don’t know, how to accomplish a “backward NAT”. Is it possible?
The real problem: I need a connection from one Windows host on a wired network (it has an IP 192.168.20.14) to one host on the wireless network (it has an IP address 192.168.60.230, which it receives from the RouterOS’s DHCP reservation). Now I’m sorting this problem on a strange way: I created a PPTP profile, which receives an IP address from the “wireless pool” and I connect this Windows host to this PPTP connection, so that it is on the same network as the wireless network - on this way the Windows host connects to the host on the wireless network.
I would like to get rid of the PPTP connection: this Windows host needs a permanent connection to the host behind the NAT.
Is there a way to accomplish it?
Many thanks in advance.
