I’m looking to set up a home network monitoring system on my MikroTik hAP ax3 running RouterOS 7.22. My current setup includes VLANs on a bridge (vlan-filtering = yes) and WireGuard. I have about 20 devices in the network (mix of static IPs and DHCP).
I want to build a monitoring system based on Containers (App / Docker) running directly on the MikroTik.
Requirements:
→ Real-time traffic monitoring per device (upload/download).
→Historical statistics (daily/monthly usage per client).
→Internet connectivity monitoring (uptime / ping).
→Security monitoring: detecting attack attempts and firewall logs (e.g., port scanning, login attempts).
→100% local operation (no cloud dependency).
→Data (logs/databases) stored on a USB drive connected to the router.
→Web interface with clear dashboards and charts.
Important Constraints:
→I use VLANs + VPN (WireGuard), and these must remain active.
→The router has 1GB of RAM – the solution needs to be resource-efficient.
What tools/app would you recommend for this?
I’d appreciate any advice or proven configurations!
Jamson
