hi
can any one help me with my problem
i have network printer in my network after microtik server and i want all user to be able to print in this printer how i can gave it STATIC IP ADDRESS from server
thanks
check the printer manual ![]()
Nothing to do with Mikrotik, You have to add the IP Manually in the Printer.
Hi ;
As i read from his request that he want the server to assign a static ip to the printer not to be entered manually to the printer .
if you have a dhcp server running in your MT and you know the printer’s MAC id , from leases search for that mac and click on it then click on make static .
then the server always will assing that ip to the associated mac id , but you should increase the lease time as possible so the server still remember the printer .
give that ip to all users so they could connect to the printer .
with best regard .
hi
thanks for your reply
yes this what i want
thanks for your help
