Hi, new to mikrotik. Just got a 750g and need real basic NAT and internet routing setup on it. I got DHCP and local network setup but can’t get online.
Setup:
ATT Uverse VDSL Modem/Router with DMZ setup for 750g router.
DHCP local network: 200.1.1.0/24
750g Prints:
[admin@MikroTik] > /ip address print details
expected end of command (line 1 column 19)
0 ;;; default configuration
address=200.1.1.1/24 network=200.1.1.0 broadcast=200.1.1.255
interface=ether2-local-master actual-interface=bridge1
1 D address=99.90.186.206/22 network=99.90.184.0 broadcast=99.90.187.255
interface=ether1-gateway actual-interface=bridge1
[admin@MikroTik] > /ip route print detail
0 ADS dst-address=0.0.0.0/0 gateway=99.90.184.1
gateway-status=99.90.184.1 reachable bridge1 distance=1 scope=30
target-scope=10
1 ADC dst-address=99.90.184.0/22 pref-src=99.90.186.206 gateway=bridge1
gateway-status=bridge1 reachable distance=0 scope=10
2 ADC dst-address=200.1.1.0/24 pref-src=200.1.1.1 gateway=bridge1
[admin@MikroTik] > /ip firewall export
jan/02/1970 02:22:55 by RouterOS 4.11
software id = VW1Q-477J
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment=“default configuration” disabled=no
protocol=icmp
connection-state=established disabled=no in-interface=ether1-gateway
connection-state=related disabled=no in-interface=ether1-gateway
add action=drop chain=input comment=“default configuration” disabled=no
add action=masquerade chain=srcnat comment=“default configuration”
connection-type=“” disabled=no dst-address=0.0.0.0 out-interface=
ether1-gateway src-address=200.1.1.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
[admin@MikroTik] > interface print
NAME TYPE MTU L2MTU
0 R ether1-gateway ether 1500 1524
1 R ether2-local-master ether 1500 1524
2 ether3-local-slave ether 1500 1524
3 ether4-local-slave ether 1500 1524
4 R ether5-local-slave ether 1500 1524
5 R bridge1 bridge 1500 1524
What am i missing? Thanks in advance!
