New CapAX - config sanity check requested
Hello all,
I decided to grab a Mikrotik CapAX in order to get some experience configuring their APs, all well as to see how the 'Tik wifi really performs. I’ve seem plenty of people declare that it is less than amazing, while others say that it works just fine for them. It was a little weird to put my head around but I think I’ve at least understood the concept? Undoubtedly there is much for me to learn. And before someone screams at me, I left the freq settings to auto just because I was merely trying to get things to work before I fine tune. One immediate question is why my phone is able to see the Homestar2 and Strongbad2 networks (5ghz) while my laptop is unable to but sees the 2ghz networks just fine. Laptop is able to see 5ghz on my Unifi AP AC PRO running OPENWRT just fine. It is a freq or bandwidth issue? Appreciate the help and criticism in advance.
Config is as follows:
# 2023-09-18 16:00:53 by RouterOS 7.11.2
# software id = IILR-ELWI
# model = cAPGi-5HaxD2HaxD
# serial number = Nunya
add name=bridge1 vlan-filtering=yes
set [ find default-name=ether2 ] poe-out=off
/interface wifiwave2
set [ find default-name=wifi2 ] channel.band=2ghz-ax .width=20mhz \
    configuration.country="United States" .mode=ap .ssid=Homestar disabled=no \
    name=Homestar2Ghz security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=all \
    .width=20/40/80mhz configuration.country="United States" .mode=ap .ssid=\
    Homestar2 disabled=no name=Homestar5Ghz security.authentication-types=\
    wpa2-psk,wpa3-psk
add configuration.mode=ap .ssid=Trogdor disabled=no mac-address=\
    4A:A9:8A:CA:1B:31 master-interface=Homestar2Ghz name=IoT2Ghz \
add configuration.mode=ap .ssid=Strongbad disabled=no mac-address=\
    4A:A9:8A:CA:1B:30 master-interface=Homestar2Ghz name=Strongbad2Ghz \
add configuration.mode=ap .ssid=Strongbad2 disabled=no mac-address=\
    4A:A9:8A:CA:1B:2E master-interface=Homestar5Ghz name=Strongbad5Ghz \
/interface vlan
add interface=bridge1 name=MGMT vlan-id=100
add include=all name=Access
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged \
    interface=Homestar2Ghz pvid=160
    interface=Homestar5Ghz pvid=160
    interface=Strongbad2Ghz pvid=120
    interface=IoT2Ghz pvid=200
    interface=Strongbad5Ghz pvid=120
    interface=*12 pvid=200
set discover-interface-list=all
/interface bridge vlan
add bridge=bridge1 tagged=ether1,bridge1 vlan-ids=100
add bridge=bridge1 tagged=ether1 untagged=Strongbad2Ghz,Strongbad5Ghz \
    vlan-ids=120
add bridge=bridge1 tagged=ether1 untagged=Homestar2Ghz,Homestar5Ghz vlan-ids=\
    160
add bridge=bridge1 tagged=ether1 untagged=IoT2Ghz vlan-ids=200
add interface=MGMT list=Access
add interface=ether1 list=Access
add interface=ether2 list=Access
add interface=bridge1 list=Access
add interface=Homestar5Ghz list=Access
add interface=Homestar2Ghz list=Access
/ip dhcp-client
add interface=MGMT
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox port=56473
set api-ssl disabled=yes
/system clock
set time-zone-name=America/New_York
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=Access
Don’t use auto.
Set frequency yourself to a non used channel.
Probably that’s why your laptop can’t see it.
Ok, I’ll tackle the freq next. Does the rest of the config look alright? If I got it 99.9% right the first time, I’d probably drop dead.
Why not wait for capAXE and wifiwave3
Or
capAX7 and wifiwave4? :-0
With any luck, Zerotier for non-ARM devices will come first!
But seriously, tell me more about my config. If it’s great I’ll port it over to capXXX or wifiwaveX.
Brief comments:
I do assume there is another router in front which takes care of all router-services (DHCP, DNS, routing, …) ?
Interface deleted afterwards ?
Use of interface lists without any form of firewall is useless. But it doesn’t hurt either.
As a dumb AP, there is not much else to look at :sunglasses:
Now for Wifi …
2.4GHz: probably crowded, try to use the channel in 1/6/11 scheme (if that’s being followed in your area) which is the least occupied. Don’t go sit in between channels, you’ll make things worse for yourself and everyone else.
5GHz: more options but given that earlier remark about your laptop, be sure to use a frequency which your devices can handle.
Choose a CLEAR channel and make sure you have room for that 80MHz-width.
Use this as guideline to select the correct 20/40/80 blocks:
https://en.wikipedia.org/wiki/List_of_WLAN_channels#5_GHz_(802.11a/h/n/ac/ax)
I prefer to decide when to upgrade and where to.
Just to follow up, manually setting the freq absolutely solved my issue with the lappy. Running strong and fast now.
This doesn't update the packages, it just updates the routerboard firmware at the same time I update the packages manually. Device reboots twice and I'm done versus having to update the packages, reboot, then log in and manually update the firmware, and then reboot.
