hello guys, today we are testing ccr2004-16G-2S+, fresh firmware is 7.0.4 since i’ve read ccr2004 reboot thread, fix is by update to 7.1rc2, i just hit system package update, router restarting but somehow i;m unable to ping (address already set) mac-ping or mac-telnet
plugin console cable, i can see that all interface from switch1 (port 1-8) flapping with rate change all the time, change cable to port 9-16 everything is good
is there any routeros 7.0.4 link ? downgrade to 7.1rc1 but same issue (port flapping)
or is there any workaround ?
Hello, please create a support file on the device (supout.rif) while it is not functioning properly and send the file with problem description to support.
You can also request a download link for the 7.0.4 package in the same ticket.
so i get replacement,
this time i won’t upgrade / test firmware
i see some menu are not available with default version: 7.0.4 (stable), it’s switch menu, i think this is the culprit
but just my 2cent
