I just powered this switch and got "poe-out status: no_valid_psu" on all POE ports
Is this a hardware problem or known configuration bug?
Know I have Routeros 7.24 but with original 7.20 was the same
check these topics found by search engine of the forum: Search results for 'poe-out status: no_valid_psu order:read' - MikroTik community forum
My guess would be that the power supply in use is not adequate to provide POE, and it is basically screaming that at you.
The RB5009 is a good example - it does have POE out, but won't do it with it's wart - it needs a beefier supply added to it's side connector, as I recall.
Please open a support ticket at https://help.mikrotik.com and attach the supout.riffile
CRS418 has builtin AC power supply.
I hope, the manufacure uses adequate one.
