New device plugged in: new default route in another router?
Hi.
We use a Mikrotik RB2011 as a company router. The router is setup to handle two internet connections, one main and one backup. The selection of the two gateways is managed automatically by different “distance” values. Works nicely. The IPv4 range is 192.168.1.xx.
Additionally we manufacture a bridge system with the Sextant G 5xxxx devices. These devices are programmed (configured) in the same switched network where the router is used. As usual the new device has the default config by Mikrotik with an IP of 192.168.88.1. For purposes of configuration via ftp/tenet/ssh one computer in the network is configured with an alias adress of 192.168.88.2 (in addition to it’s default IP address in the 192.168.1.x range).
Now the issue:
Whenever I plug in a new Sextant G5 to configure it, our company router acquires a new dynamic route to 192.168.88.1 in the routing table. Since this new route has a distance of 1 (one) this becomes the new default route. Since this route is a dead end all internet access comes to a halt and my colleagues start screaming at me. I would like to stop the screaming :slight_smile:
My question:
How do I prevent the RB2011 router from acquiring a new dynamic route, just because another device becomes reachable in the same switching network. How is this even discovered?
many thanks.
Ekki
Looks like you have a DHCP-Client enabled on your LAN-facing interface (which IMHO doesn’t make sense at all) with the add-default-route=yes parameter.
Remove this and the problem should be gone.
But beware that the Sextant will still act as DHCP server in your LAN - so clients which connect right in the moment before you wipe its config may receive a lease from the Sextant.
-Chris
Oh my… how did this happen? Ok, I have disabled the DHCP client now and will test, but I am pretty much certain that that was the reason. Many thanks.
The DHCP servce on the Sextant is something I have to live with for a few seconds, it is disabled during configuration later on.
Thanks again,
Ekki
Welcome to the forum Ekki!
Always nice to see people from the old packet network days.
Hello Rob,
now that’s a long time ago :smiley:
How far have we come along, from 1200 bps packet radio on a 25 kHz channel to 150 MBit/s links (or more) on 80 MHZ :slight_smile:
73,
Ekki, DF4OR
Yes and much cheaper too :slight_smile: This MikroTik equipment has very good prices compared to the old sytems.
We are quickly expanding the HAMNET network in the Netherlands, but it is not as extensive as in DL yet.
73,
Rob
