I'm replacing my current hAP ac2 as my primary router with an RB5009UG +S+I and am thinking of replacing my current AP's, which are TP-Link EAP225s. I want to move away from TP-Link and obviously going to MT APs like the AX1800 would make it a nice all-MT ecosystem, but where I am, the Ubiquity u6+ is around $20 cheaper (I need 3) and has comparable specs and great reviews. I'm looking for feedback on the Ubiquity and thoughts on whether or not they are superior or is the MT AP a better choice, especially given my router setup.
should've bought rb5009upr and get cap ax's, i have 2 and the setup works flawlessly, i have a crs310 for my wired stuff.
Hi, thanks for the speedy reply. The 5009UPr is 3 times the price here, and it looks like the only major difference is the POE out, which I don't need on the router as the 3 AP's are the only POE devices in my setup (and the ax1800s come with the POE adapter). As far as performance goes, it sounds like you are happy overall with the ax's, have you had any exposure to the Ubiquity stuff for comparison?
I've personally had ubiquity u6 pro's and i had two other friends who had full unifi setups with the same ap's (u6 pro's), in my setup it made literally no difference they are great for a way more denser environment like a busy business office with like 10 people inside that use wifi, the difference is in the radios mainly which are 4x4 rather than on cap ax's 2x2, i also do have a hAP ax for the outside and it's been serving me great, snow rain, sunlight, zero issues.
I chose the rb5009upr since the price difference for me has been literally 15€ from ug to upr, only because of the PoE out, it made routing poe for the AP's a lot cleaner and didn't have to use the included poe injectors (not that theres something wrong with them or anything i just choose not to use them because its easier to manage the cables)
Also a role player for me was that i can use CAPsMAN to manage my AP's all from one router and its honestly amazing, i love it.
For the AP's they do everything i wanted perfectly, 3 ssid's with each of its own vlans, on 5ghz i get 850-900mbps. It's stable, i haven't had any issues with the ap's themselves even tho they run kinda hot, they are at 65-70C on the chip for me most of the time.
One and only drawback for me is that they are kinda big, the plastic enclosure is kinda big, its the size of like a bedroom light fixture.
I went for the MT ecosystem. I have a 5009, crs310 for wired devices and 3 ax2 via capsman for wifi. It works.
RB5009, 3x CAP-ax, an haP-ax2, and soon a waP-ax, POE via a CSS610, managed with CapsMan. Zero issues and performs well here.
I have an RB5009UPr+S+IN and two hAP ax² devices here. They work perfectly with Capsman. You need to use a compatible 24V power supply so that the hAP ax² devices can run directly via PoE.
Why not the hAP AX3 instead of the RB5009?
For me, it's because partially because a router routes and an AP provides wireless, and I don't mix them. (I also have 32 other switched ports I didn't mention - out of context here.)
Also, the RB5009 has SFP+ and I run a 10G optical backbone, and the 5009 is likely also faster.
It also will comfortably run containers.
Sparing is also a factor.
Rb5009 itself looks cooler is passive, a lot of people have it and is already tried and true it just works, it works under almost all temperatures and you can use it outside, its faster, it has all port poe, it has gigabyte of ram and it has a very powerful cpu, its also an arm64 device it supports http/s 2 protocol for DoH, i uplink my crs310 through a 10gig pipe (so i use the spf+ cage).
I separate my switching routing and wireless because it makes sense to me and i can just add more ap's to the same setup my just provisioning them from the capsman with already setup profiles and it will just work the same as the other 2 do.
Thanks for all the responses. It sounds like everyone is happy with their ax's, and I have to say I like the idea of going with the all MT ecosystem. The main reason I'm also looking at the Ubiquiti stuff is because almost every networking guy I know uses them at home, although that may just be fanboi stuff. As to the choice of the 5009 as my R1, it's primarily because it's tried and true and has all the hardware capabilities I need, and also, where it's located in my house, I can't use the WiFi capabilities, so the AC3 isn't really suitable. I have to say though, right after I bought the 5009, I saw the post about the Hex-Pro and now I'm wondering if I should have waited to see what that sells for. Seeing as it's not even on the market yet though, and given the specs, I imagine it's going to go for at least double what the 5009 cost me. One other thought I had was that I can use the hap ac2 as an AP as well, but given the difference in specs I'm not sure if it will fit in well with the ac1800's.
Experience with unifi ? Switches are sh*t. I have Unifi at my parent's house and under a year USW Lite 8 PoE failed. Bought USW Flex 2.5G 8 PoE and after a year it started failing as well. I replaced it with CRS310 and a PoE injector for the AP and no problems whatsoever.
Their UCG Max is constantly running at 77-82 degrees so I expect that it will fail soon.
AP's are good. Never had any problem with them.
But I seem to remember that you reported some issues with Mikrotik's AP's, didn't you?
I.e. is your suggestion:
a) Mikrotik for switches and routers
b) Unifi for AP's
The manufacturer that begins with C and ends with m cannot (besides the higher cost) be recommended at the moment.
Hap ax^2 (CAPsMAN) Cap ax, Zero issues these days. 7.23.8 Rock Solid for my home setup 10 clients.
Yes, when RouterOS version was 7.8. and when Mikrotik's WiFi was unusable.
Now, after some time, I would say that Mikrotik's WiFi is stable enough to be on "to buy" list.
That, ofcourse, doesn't mean there are no problems, for eg with hAP be lite right now, or hAP be3 availability, or just simple lack of true WiFi 7 APs.
But ax lineup of APs from Mikrotik are good enough.
I always try to be objective in my opinions. And based on my experience and from experience of my friends that have unifi i can't recommend their switches. At least not "consumer grade" ones.
To put things in context U6/U6 Pro had 18/24 months head start on Cap ax et al.
Mikrotik Wifi 6 products had a shaky start as we all know, new users however can thank us for the pain of testing.
and I am happy to say Cap ax is a solid option with cpu to boot. It makes short work of our new Steam Frame addition.
Yea, I'm especially happy with wAP ax. cAP ax is great but a little too big sometimes... I would like to see something from Mikrotik that's the size od cAP ac but ax, or a little bit bigger, like U6+. cAP ax is bigger than U7 Pro... Which is tri-band AP...
You haven't yet seen my project (rendered by infabo), not that the good Mikrotik guys will ever adopt the idea, still ...
Starting here, the dAP (or doughnut AP)
I saw it, I even gave you few ideas ![]()
Not sure the design driver, but the physics of antenna design pretty much drive the size. Smaller means less gain, which means higher TX power (and consumed power and heat) for the same output signal (and the need for a more elaborate preamp to hear the incoming.)
I dunno . . . The Wifi6 Netgears I replaced with CAP-ax were square, but overall not much smaller. (But they were a lot more crippled!)
