new in scripting
hi guys
i use webproxt-test
in the proxy i blocked users to download video (avi , mpg .wma , wmv .... )
ip proxy access add path=avi action=deny
ip proxy access add path=:.mpg action=deny
ip proxy access add path=:.wma action=deny
ip proxy access add path=:.wmv action=deny
now i need to allow users to download these extension from 12am to 6am
so i scripted these rules and schedule it
[admin@MikroTik] > system script print
0 name="n3" owner="admin" policy=ftp,read,write,policy,winbox run-count=0
source=ip proxy access add path=:.avi action=allow
1 name="n1" owner="admin" policy=ftp,read,write,policy,winbox run-count=0
source=ip proxy access add path=:.mpg action=allow
2 name="n2" owner="admin" policy=ftp,read,write,policy,winbox run-count=0
source=ip proxy access add path=:.wma action=allow
3 name="n4" owner="admin" policy=ftp,read,write,policy,winbox run-count=0
and i
[admin@MikroTik] > system scheduler print
Flags: X - disabled
NAME ON-EVENT START-DATE START-TIME INTERVAL RUN-COUNT
0 night n1\r\nn2\r\nn3\r\nn4 feb/24/2007 00:00:00 6m 7
what's wrong with these rules
you should not add and remove rules with scripts. better disable and enable existing (working) rules.
what u mean
i don’t understand
not like this
2 name="n2" owner="admin" policy=ftp,read,write,policy,winbox run-count=0 source="ip proxy access add path=:.wma action=allow"
but like this
2 name="n2" owner="admin" policy=ftp,read,write,policy,winbox run-count=0 source="ip proxy access enable NAME"
thanx for ur replay normis
ok i do this i hope it's right
proxy
script
0 name="mpg" owner="admin" policy=ftp,read,write,policy,winbox run-count=0
source="ip proxy access enable mpg"
1 name="wma" owner="admin" policy=ftp,read,write,policy,winbox run-count=0
source="ip proxy access enable wma"
2 name="avi" owner="admin" policy=ftp,read,write,policy,winbox run-count=0
source="ip proxy access enable avi"
3 name="wmv" owner="admin" policy=ftp,read,write,policy,winbox run-count=0
source="ip proxy access enable wmv"
scheduler
[admin@MikroTik] > sys scheduler print
Flags: X - disabled
0 avi avi jan/01/2007 01:00:00 0s 0
1 wma wma jan/01/2007 01:00:00 0s 0
2 mpg mpg jan/01/2007 01:00:00 0s 0
3 wmv wmv jan/01/2007 01:00:00 0s 0
ok now i scheduled to enable downloading these extention at 1 am
now how to disable it at 6 am
thanx again
add new scripts that will do the disable, and then add another scheduler rule that will run those other scripts. it’s the same as you have now!
It’s not gonna work
as enable command expects item number
To enable all entries in access list use:
/ip proxy access enable [f]
And to disable use:
/ip proxy access disable [f]
what do mean [f]
i do not understand what u mean by that [f]
can u do it for me
plz
im new in mikrotik :blush:
just write [f] in your script. [f] means ALL
ok thanx
i did this
0 name="block_download" owner="admin" policy=ftp,read,write,policy,winbox run-count=0
source="ip proxy access disable [f]"
1 name="open_download" owner="admin" policy=ftp,read,write,policy,winbox run-count=0 source="ip proxy access enable [f]"
Flags: X - disabled
0 block_download block_download jan/01/2007 06:00:00 0s 0
1 open_download open_download jan/01/2007 01:00:00 0s 0
tell me it’s gonna work and make me happy :laughing:
it should work fine
:smiley:
thanx man
preciated ur assistant
:cry:
help me :frowning: it’s not working
in 1am it’s work fine (enable to download avi,mpg …)
but at 6am it’s does’t disable it
im crying now
you have to set interval for sys scheduler rules. In your case it runs only
once
jan/01/2007 01:00:00 and
how to make it work every day in the set time
just set interval to 24 hours
