Originally my ADSL line was connected to the original telephone exchange and it was like 1500 meters long, but when VDSL was deployed the telco put special cabinets in areas affected by that and now my line is only about 100m. So it is fast and stable. I could double the speed by adding another telephone line (bundled), my modem supports that but it costs extra per month and I do not require it.
In fact when I would put pressure on the FTTH guys I probably could get the connection, it seems that they prioritize the customers with the loudest voice.
even if you throw in an external ONT or DSL modem you will end at not more than for the FB
and still have a way more capable setup
So I wonder why the RB5009 is perceived as expensive and there is a demand for something even cheaper? I mean, I get it, cheaper is always nice, but the bang for the buck of MT devices is insane (-ly good!)
Well, a Fritzbox has (working) WiFi and usually a modem for DSL or Cable and often telephone support (analog/ISDN/DECT). It is a home connection center rather than a router, they are not comparable.
The typical Fritzbox user is probably better served with a hAP series device (ax S, ax2, ax3) because they would want to replace their router with one device and not with two.
We geeks are different of course and enjoy a nice router + switch + APs with CAPSMaN etc
You are absolutely right that compared to a Fritzbox or enterprise Cisco gear, the RB5009 is an absolute steal. I completely agree that MikroTik's overall bang for the buck is incredibly good.
However, my point isn't about comparing MikroTik to other brands. It's about comparing MikroTik to its own hardware lineup. I am not saying the RB5009 is overpriced for the hardware and features it provides. The issue is the massive gap between the entry-level hEX or L009 and the RB5009.
I'm not asking for a cheaper RB5009. I am asking for a mid-tier device that simply fills that internal void - a purely wired Gigabit router that can handle a 1 Gbps connection without FastTrack, stripped of premium extras like the 2.5G port or SFP+ cage.
It's not about beating a Fritzbox in pricing; it's about MikroTik offering a balanced, logical step-up in their own product ladder.
Ok but many more persons here are asking for things like an RB5009 with 2.5Gbit ports, so probably you are quite alone with your "1Gbit but cheaper than $220" demand.
Also note than an SFP cage costs nothing. It is basically an ethernet port without the hardware (link protocol chip + isolation transformer), just a simple metal sleeve and connector directly to the switch chip.
It may look exotic but it does not add to the hardware cost, in fact it reduces hardware cost when the alternative would be an extra RJ45 twisted pair port.
I like to add: Most important for any of these devices: Do they get updates for a long time? And in this AVM/Fritz and MIkrotik are shiny diamonds. That worth money as well! There are many shit on the market with fired-and-forget-software some months after buying.
I drive both: a Fritzbox -> DMZ -> Mikrotik RB5009 (before since many years with RB3011). Works fine
And by the way: I buy used Fritzbox as I run my wifi via MT. Hence, a Fritzbox 5530 for 70€ is sufficent for my new FTTH. Must not be expensive - and more money for MT
MikroTik provides updates much much longer than AVM/Fritzbox! That is because each Fritzbox model has its own firmware, and when the device is end-of-sales the updates for that particular firmware version are no longer compiled and released. Maybe with the exception of major security updates.
MikroTik still releases monthly firmware updates for devices developed and sold over 15 years ago. That is possible because all devices with the same processor run the same firmware image, so there are often models with the same processor that are much newer, and are still supported.
I partially get the 1Gbps native throughput wish. Yes, this is nice as you could apply filters, mangle, routing, QoS and all that good stuff.
However I have 1Gbps WAN available which is almost never fully used. If it were fully used, the buffer in client applications fills the gaps. By all means, for gaming and other real-time applications I see the need to do some queuing / shaping or whatever.
Then still, you don't have to use the out-of-the-box fasttrack. Using connection marks, it is quite easy to fasttrack some traffic while omitting other traffic?
I have not felt the need to disable fasttrack on my CPEs actually. Could be I am just not observant enough.
On my CHR which acts as a hub I do have fasttrack disabled due to mangle rules and routing stuff. Little bit out of the scope of this discussion though.
Let's not get sidetracked by the exact manufacturing costs of an SFP cage. Whether it costs nothing or not misses the bigger picture.
Also, I highly doubt I am alone in this just because some power users are asking for 2.5Gbit ports.
There is a massive number of standard home and small office users who simply want to route a standard 1 Gbps connection reliably.
My core point remains straightforward: we just need a reasonably priced, mid-tier router that handles 1 Gbps without FastTrack, without forcing us into higher price brackets, and without requiring endless debates. We just need a solid, simple device to fill the obvious gap in the current lineup.
Well, by now you should have already bought an AX3 and started living happily with It.
And yes, you might miss the three extra ports and the missing SFP, but what do you want from 140 bucks, blood?
Yes, the RB5009 is the only answer currently available in the lineup. But that is literally the entire point of this thread - we are forced to buy it because a proper mid-tier option simply doesn't exist.
Pointing to the RB5009 just proves my point that there is a massive gap in the market.
I am perfectly aware that I have choices, which is exactly why we are discussing what is currently missing from them.
Discussing the need for a mid-tier device on a manufacturer's forum is just normal user feedback.
It is amazing that Mikrotik has been making stuff successfully for 24 years bereft of knowledge of what might constitute a "mid-tier" or a viable product line-up.
It's not missing.
RB5009 is the device you need as speeds&user demands getting higher and higher, so capabilities of your router should be ahead of the current needs.
As I wrote earlier: there are additional costs that have to be paid to produce such a device and then, when delivered, it turns out that it got outdated already and the endprice is not as satysfing at it was expected.
What we talk about? One time 20$ or 40$ more? I know it's "some money" but how much do you pay for your Internet access? How much do you pay for your phone subscription each month and how much of that is the installment for the devices you got almost "free"?
Not too many remember that usually if you have an Internet subscription and the router for "free" then you pay monthly fee for that even if the cost of that device is already paid off. Then you just pay for nothing, not nothing, for insurance that if something wents wrong, you get a new device. The "dark side" of that situation is that usually you are allowed to do almost "nothing" with that device. But it is the price for a "free" cheap device.
Something for something.
I went through 5 devices including quite capable second hand 1100AHx2 and 2004PCI till 5009 has found it's place at my home. And I am at easy knowing that I do not need to worry about "what if I want to have higher speeds"?
