Yep, that's exactly the reason why I replaced my aging Panda with a Porsche 911.
But I miss the large trunk space.
Seriously, each device has its own ups and downs, and everyone would like a different device, perfectly tuned to his/her own needs.
As an example, the way I see it, a router should have three ports, a console/serial, a WAN one and a LAN one, if you need other ports you add a switch on the LAN side.
A USB port (for disks, etc.) has no reason to be on the router (it should be on the switch).
Radios/wifi make as well little sense on a router, as the location where the DSL/cable is rarely in the "right spot" to also offer centralized wi-fi, even in small houses.
And it should be of course quite cheap - it's not personal at all, just a statement.
Some avoid additional switches and prefere more ports in the one and the only device.
No way to bridge the gap.
The CCR2004-1G-2XS-PCIe is what you need, in a case that provides it with power. I don't understand why MikroTik has made that niche device and does not sell the same PCB in a case + powersupply.
A huge issue for us currently is that we are looking at replacing a number of older 60GHZ stuff from ubiquiti, We do not want to buy their latest gen stuff due to a huge number of issues and us having absolutely zero confidence in UBNT after the last few years of them absolutely bending over MSPs that were with them from the start and doing everything they can to shit on them.
The Nray Gen2 was looking like a godsend when it was announced. But the absolute zero information from Mikrotik combined with that other devices have dissapeared on the 60GHz front are making us worried. Best case they are clearing stock to make room for the new Nray, worst case they are pulling out of 60GHz except for short to medium range stuff, but we cant know since they are giving us zero info.
Funny. I've been slowly replacing my MikroTik 60GHz with either Ubiquiti Wave or Tachyon 300-series radios. The Peraso radio is far superior to the Qualcomm radio in all ways: 1/2 bandwidth (1080MHz) option, greater distance, 30+ users per AP, and great throughput.
And, unfortunately, nobody has a decent, simple omni-directional 60GHz solution.
MikroTik should be making a Peraso-based product lineup, if they aren't already. Combine the 5009/2004's CPU in an AP package with 2 (90-180°) or 3-4 Peraso radios in a 360° configuration and you'd have a very capable solution.
Actually there is exactly the device you need, you only must digest the fact, that the PCB, box (but aluminium!) and PSU are being sold separately. Incl. the box it even costs similarly to L009 (118 USD). The winner is RB450Gx4 - 5x1G ports on switch chip, 2 Gbps bus to 4cores ARM32 CPU and it's performance in routing with 25 FW rules at 512 bytes is 912 Mbps. IPsec at 512B is 155 Mbps, at 1400 B is near 400 Mbps and it has an DB9 port
I plan to replace our CCR1072 with the CCR3232 next year. I dont want to replace with Gen2 CCRs if the Gen3 are in the pipeline. We had to make budget for 2027. What sum should I enter here? No information, nothing, not a single word.
As private person I wait for the mAP ax, same, nothing, not even a preview like for thier CLAIRs.
