New Mikrotik Hardware showed in MWC 2026
@MatiasMK88 was the downvote for this post because it was inaccurate? If you know when it will be released, do you care to share?
Honestly, yes. I have less devices to manage and, generally, PON module are kind of plug-and-configure once. At least, with Digi, Telefonica, Orange and Vodafone (main spanish ISPs) is easy to find the way in and there are even several tutorials on how to do it.
I have the hAP Ax S with a GPON stick and it works flawlessly. Actually, I had less headaches, because ISPs some time to time they do updates and they set to default everything, although it is quite uncommon (even to touch the router).
Does the provider sell you the SFP or do you buy that from somewhere else?
When you buy it yourself you need to have it configured into their system. While formally they are obliged to facilitate that (due to EU rules), in practice it is often a struggle, and when you have link problems you are on your own. "we cannot run our familiar tests" etc.
Here the delivery of bare fiber has been tried for a while but the experiment was abandoned and now all fiber connections are again terminated on RJ45 in the NTU.
Yeah, I know what you mean in it is totally understandable. Myself, I've seen that in many hotels. However, the issue is that the NTU is set in bridge mode and it is the bottleneck or it is a one router more becoming even more the bottleneck. With an SFP you buy yourself you can buy a better or worse one, but you can decide. As said, this is at own risk, but I prefer it.
In Spain, they don't explain how to do it directly but often it's just clone the SN or the password and set the VLAN in the MikroTik. At most, some providers like Digi, they give you the username and password for PPPoE.
For me personally it would be nice to have wAP be with MultiGig Ethernet port, like 2.5Gbps. Also a Chateau with WiFi7 and MultiGig Ethernet ports would be quite nice.
For me - S009 and Hex Pro in RB5009 case! Both will fit perfectly in my home rack :slight_smile:
Is it only me or there is really a lack of and a need of, mulitgig poe++ switches both in indoor and outdoor form? Waiting for a 5009 outdoor variant or powerbox with multigig ports (2.5,5,10G) and at least poe+, if not poe++ support per port. hEX Pro PoE at least in an outdoor form. C'mon guys you announced these back in March.
You mean ... this ?
https://mikrotik.com/product/rb5009_out
WiFi7 APs and MultiGig switches???
Anyone?
The RB5009, both the normal indoor and outdoor version is - strictly speaking - not capable of PoE 802.3at output as 57Vx0.440=25.08W, while being in the role of a PSE it should provide 30W.
Or - if you prefer - it is 2/3 along the distance between POE and POE+.
TL;DR: The POE-out version of the RB5009's is gutless. The 440mA current limit cripples it for anything that wants 24W+, and when you factor voltage drop over some runs to 48-44V, you're lucky to get 19-21W out of it.
MikroTIk and Ubiquiti have both done this: release wireless gear that needs/uses higher power, but then no switch to support it. Or release a switch that supports some wireless gear, but only indoors (or low-power), or active vs. passive, or some odd voltage arrangement.. Or high power but 1G instead of 2.5G, or 2.5G but no POE. Or 10G but no SFP cages.
