New Mikrotik Hardware showed in MWC 2026
I guess everyone would like to see something different and everything that MikroTik offers is just one step away from what one would like... 8 ports is often not enough and those switches are all quite bulky as well.
CRS310 consumes max 34 W. So if you use two passive PoE injector where the second one used as extractor at the CRS310 side, you just need to use adaptor (jack-jack) or fit manually proper barrel connector to be plugged directly to the CRS310's power in. If you feed 48V through this, you will pass 0,7 Amp maximum/ 0,5 Amp without attachments..... not the best but it might work especially if you use lower number AWG cable (thicker wires)
And then what ? I want PoE out... Not interested in PoE in devices... Mikrotik lacks proper poe switches in 5-8 port category...
You can run a hEX PoE as a 5 port switch. I plan to do that to power 2 to 3 hAP-ax2.
RB960PGS exist.
which can, maybe, do 1Gbps if you're lucky.
Old architecture, no 2.5G support and sfp+ and if you want hw offload vlans then you need to play with switch menu. I have couple of them...
So to recap, Mikrotik lacks modern architecture, multi gig, 5-8 port poe switch.
Incoming hEX Pro PoE will probably fix that.
L3, yes, but not as a switch. That's line rate.
S009 will close this gap.
As written before, my ideal home router would be CRS418-8P-8G-2S+5axQ2axQ-PC
where's mAP ax? that was the most interesting device
Yes, would be better passive cooled and desktop case. CRS418-8P-8G-2S+5axQ2axQ-RM - has anyone ever asked for a rack mount device with wifi?
Yeah, a smaller-width case and passive cooling would be ideal for here in the room.
I guess the potential issue is to have connectors for the antennas and power + the passive cooling all on the back. I would want the case to be like the CCR2004-16G-2S+PC but of course that does not have WiFi antennas.
https://www.youtube.com/watch?v=NSiljceTi0o&start=207&end=217
Can't that creepy guy ask "can we have a tabletop model"?
When do you thing the new hEX Pro and hEX Pro PoE be available or officially announced? so far only the hAP be lite has been released (and has been, at least to me, a great product)
The only people that know that (I don't) probably are not allowed to say anything (they probably had to sign a non-disclosure agreement NDA). Edit: google claims they don't have NDA either.
Yeah, I guess they cannot. I wish they present it sooner than later...
By the way, the hEX Pro PoE is perfect for a XGSPON Stick. In Spain, most ISPs are already rolling out WiFi 7 and 10Gbps already
But is it practical to use an externally sourced XGSPON SFP with such a connection?
In many cases that will give a lot of headaches and you end up with an unsupported solution...
