I have recently installed a network at my home which includes the MikroTik Hex 5 port router with a 24 port D-Link unmanaged switch.
The install really went seamless. Everything is up and working fantastic… except…
On one laptop in the house (MacBook Pro), we have 2 Cox email addresses that will NOT connect to their outgoing smtp mail server.
Error: Could not connect to this SMTP server. Check your network connection that you entered the correct information in the Account Preferences. Also verify that the server supports SSL. If it does not, deselect the “Use SSL” Checkbox in the advanced tab of Account preferences
Things I’ve tried -
plugged directly into the MikroTik router to eliminate the other pieces of the network and still did not work
tried from my hotspot on my phone and it sent with no issues
tried various ports for the smtp server - 465 (default), 557
tried turning on/off SSL
Tried both wired and wireless on the network and still the same error.
I’ve looking through just about every setting on the router and just don’t see anything that stands out to me. This is my first Mikrotik and I’m sure I’m missing something obvious.
When you want other people to debug your configuration you need to include it with your posting.
So run a /export to a file and include the file with a message. (removing any passwords appearing in there)
I don’t see anything in your config that could block outgoing smtp. In fact, it looks like almost untouched default config, and it does not block anything outgoing.
Try to use port 587, that’s the right one you should be using.
Yes, that’s exactly what it is. I plugged it in and didn’t touch anything (that I know of). I’ve tried port 587 with absolutely no luck. That’s why I’m so perplexed.
You need to eliminate all other things to troubleshoot this.
Switch off your wireless on the laptop, plug it directly into the MikroTik with a network cable. Take the switch and everything else plugged into the MikroTik and disconnect it, except for the WAN connection and your laptop.
Does the problem still happen? If it does, then proceed to disconnect the MikroTik and plug your laptop directly into the Internet so that it gets an IP direct from your provider. Does the problem still happen then?
Your router does not appear to be the cause of this problem…
Did you move to another ISP at the same time? Did you get a different public IP address?
It may be a configuration error at the ISP, that sometimes happens when they start using a new network address block.
