New RouterOS BETA is out: v3.0beta3
Please, add this feature in RouterOS if it is possible:
  • to set different MAC addresses for different VLANs on the same ethernet interface
any hope to see 802.11e supported with nstream enabled???
Regards
Rosario
Fore, Any new news regarding your testing of Nstreme + CSMA/CA
in high noise environment ?
High Regards,
Andrei
haven’t tested beta 3 performence yet (been a little busy, we just finalized the purchase of another WISP a few days ago, we’ll be doubleing our current size and coverage area with the new addition, plus we just put our first SR9 900Mhz cell up a week and a half ago which is doing pretty well, nearly a dozen customers on it already)
I posted some beta 2 test results here
http://forum.mikrotik.com/t/beta-2-nstream-performance/9873/1
this is not planned.
Dear Normis, uldis,
When we could expect beta4 is out ?
Thank’s in advance.
High Regards,
Andrei.
if you have a spare PC, and some free time - please install beta 3 with a demo license, and test the basic features. report to us if you find some problems. we still have not received any important bugreports.
I have seen only one from B3.
I installed it on a SuperMicro Dual P4 Xeon 2.4 Hyper Threader.
I had both CPUs installed, 1GB ram, Hyperthreading active.
Here was the issue:
The router only recognised 3 CPUs.. I can not say if the system posted as 4 CPUs or not, but when the system was rebooted, it recognised all 4 “Cores”..
I have had no other issues with B3..
Craig
Things that make you go Hmmmmm…
Installed B3 on an RB112 for testing. Wireless performance was much improved over 2.9.30.
The only issue was the terminal window (in color) was very sluggish while typing and printing.
in where, in ssh, over console? what program did you use?
i tried with dirrect monitor, for x86... !!!
i think with spelling command.... it's nice .. cool
Hasbullah.com
Come to think of it…
I had some of the same console issues from the router’s console as well as from the “new terminal” interface within winbox.
Craig
New Bug Report for Beta-3 :
I’m cannot restart router reliably,
sometimes it can, and sometimes its cannot ? :slight_smile:
High Regards,
Andrei
What hardware? Any console messages?
WRAP-2C, Bios V1.11
I’ve tried with demo licensed and l4 ones.
Same result, even with different board.
No, strange console messages in telnet / hyperterminal (serial) console.
High Regards,
Andrei
Any user that had the same issues like me ?
High Regards,
Andrei
i changed our test station to v3beta3 alls working fine but i see the cpu load stays on 100% all the time its a rb500
done bandwidth test everything great only cpu load at 100%
disable the “dude” package…
Best regards
Thanks now i can carry on playing with it
On a SuperMicro board, I dont have the number at hand, I ave 2x hyper threader CPUs (xeon 2.8) Most of the time they are seen as 2 cups each, sometimes on a cond boot they show as three…
On a Proliant DL140 a single hyper threader (with firmware setiiing set to on… :slight_smile: ) allways shows 1 CPU…
Craig
Things that make you go Hmmmmmm…
