new static and dynamic mesh wds-mode
Can anyone explain the difference between static and dynamic wds and static and dynamic mesh that have appeared in ROS v.3?
There is no reference in the manual to these mesh modes.
Anyone??
you can try to search the forum for this feature.
We will impove these modes, but currently they are more advanced WDS modes. If you are planning to use lot of WDS running v3.0, then you might considering using this new mode.
The new mode includes authentication process for WDS links that isn’t implemented in the regular WDS mode.
Note that old WDS isn’t compatible with this new one.
Hi!
I know, that the post is quite old, but I have got the same question…
What is the difference between wds-mesh and wds?
Best wishes,
Stril
