I want to configure dual WAN on the Mikrotik HAP AX3 with campground Wi‑Fi as WAN1 and Starlink as WAN2, using automatic failover based on link health / connectivity checks. Starlink should take over only when WAN1 fails. Any help or guidance would be greatly appreciated. TIA
Here's something I was working on a while back to auto-configure dual wan deployments including linking to a zerotier network. It's setup as a script to run on boot after a reset configuration. This is designed for dual ethernet DHCP WAN connections so you'll need to do some tinkering to use the Wifi as a WAN Link (hint: station bridge)
You'll need to review the variables that are set (lines starting with ":global") to something appropriate to your configuration. All of the DNS servers noted are there for the policy based routing so that it ensures that the server is pingable through each WAN interface in order to decide which one to use, by default ether1)
Then the section on basic bridging will need to be adapted to the interface names of the HAPax3 you want to use here and add in your configuration for the Wifi. And also the embedded DHCP client scripts will need to be updated for the interfaces you've assigned for the WAN.
There are mainly two ways to obtain what you want.
- Netwatch, here is the simplest approach possible:
Simpler Failover for two Gateways I found working - #19 by jaclaz - recursive routing (basically you use a known reliable site as "virtual" gateway), here is the simplest way to make a recursive route explained:
Simple recursive failover for bears of little brain
Since you are new, it is advised that you go through these, before anything else:
The twelve Rules of Mikrotik Club
GP & CSA (Good Practice and Common Sense Advice) for Mikrotik devices
Where? ![]()
Doh! Thanks for the heads up @jaclaz
Thanks for all the suggestions and ideas. Been working on this setup for 3 days and it is highly frustrating. Sometimes the commands to set things just simply do not change anything in the config. I was able to create my own SSID and join a PC to it but no internet. Mikrotik said it was a captive portal or client isolation on the wifi I was trying to connect to but this is not true and I can connect to the same wifi with a phone or pc.Maybe I am missing something and it's probably simple.
Sure, but don't worry, it is normal to have some initial issues, you need some time to get the knack of it.
When/if you are stuck, post your configuration together with description of yout network and what goals you have and someone will be able to give you some advice.
Instructions how to post the configuration here:
Forum rules - #5 by gigabyte091
Wow, I thought the export command would anonymize the exported config. Yikes, it wasn't even close! I think I got it now. Here my current config.
2026-06-07 05:33:06 by RouterOS 7.23.1
software id = XXXXXXXXXX-XXXXXX
model = XXXXXXXXXXXXXXXXXXXXX
serial number = XXXXXXXXXXXXXXXXX
/interface bridge add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
/interface wifi set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=" XXXXXXXXXXXXX " disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
/interface list add comment=defconf name=WAN
/interface list add comment=defconf name=LAN
/interface wifi security add authentication-types=wpa2-psk disabled=no ft=no ft-over-ds=no name=sec1
/interface wifi security add authentication-types=wpa2-psk encryption=ccmp ft=no ft-over-ds=no name=uplink-sec wps=disable
/interface wifi security add authentication-types=wpa2-psk encryption=ccmp ft=no ft-over-ds=no name=clean-sec
/interface wifi security add authentication-types=wpa2-psk name=test-sec
/interface wifi configuration add channel.band=2ghz-n .width=20mhz mode=station name=wan-conf security=uplink-sec ssid="XXXXXXXXXXXXXX"
/interface wifi configuration add channel.band=2ghz-n .width=20mhz mode=station name=clean-conf security=clean-sec ssid="XXXXXXXXXXXXXX"
/interface wifi configuration add mode=station name=test-conf security=test-sec ssid="XXXXXXXXXXXXXX"
/interface wifi set [ find default-name=wifi2 ] configuration=test-conf disabled=no
/ip pool add name=default-dhcp ranges=192.168.88.10-192.168.88.254
/system script add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r
\n :if ([system leds settings get all-leds-off] = "never") do={\r
\n /system leds settings set all-leds-off=immediate \r
\n } else={\r
\n /system leds settings set all-leds-off=never \r
\n }\r
\n "
/system script add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r
\n :foreach iface in=[/interface/wifi find where (configuration.mode="ap" && disabled=no)] do={\r
\n /interface/wifi wps-push-button $iface;}\r
\n "
/disk settings set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
/interface bridge port add bridge=bridge comment=defconf interface=ether2
/interface bridge port add bridge=bridge comment=defconf interface=ether3
/interface bridge port add bridge=bridge comment=defconf interface=ether4
/interface bridge port add bridge=bridge comment=defconf interface=ether5
/interface bridge port add bridge=bridge comment=defconf interface=wifi1
/ip neighbor discovery-settings set discover-interface-list=LAN
/interface list member add comment=defconf interface=bridge list=LAN
/interface list member add comment=defconf interface=ether1 list=WAN
/interface list member add interface=wifi2 list=WAN
/ip address add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
Interface not active
add interface=wifi2 name=client1
/ip dhcp-server add address-pool=default-dhcp interface=bridge name=defconf
/ip dhcp-server network add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.1,8.8.8.8 gateway=192.168.88.1
/ip dns set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall filter add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
/ip firewall filter add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 in-interface=lo src-address=127.0.0.1
/ip firewall filter add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN
/ip firewall filter add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=in,ipsec
/ip firewall filter add action=accept chain=forward comment="defconf: accept out ipsec policy" ipsec-policy=out,ipsec
/ip firewall filter add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related
/ip firewall filter add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat in-interface-list=WAN
/ip firewall nat add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN
/ip firewall nat add action=masquerade chain=srcnat out-interface=wifi2
/ip firewall nat add action=masquerade chain=srcnat out-interface=ether1
/ipv6 firewall address-list add address=::/128 comment="defconf: unspecified address" list=bad_ipv6
/ipv6 firewall address-list add address=::1/128 comment="defconf: lo" list=bad_ipv6
/ipv6 firewall address-list add address=fec0::/10 comment="defconf: site-local" list=bad_ipv6
/ipv6 firewall address-list add address=::ffff:0.0.0.0/96 comment="defconf: ipv4-mapped" list=bad_ipv6
/ipv6 firewall address-list add address=::/96 comment="defconf: ipv4 compat" list=bad_ipv6
/ipv6 firewall address-list add address=100::/64 comment="defconf: discard only " list=bad_ipv6
/ipv6 firewall address-list add address=2001:db8::/32 comment="defconf: documentation" list=bad_ipv6
/ipv6 firewall address-list add address=2001:10::/28 comment="defconf: ORCHID" list=bad_ipv6
/ipv6 firewall address-list add address=3ffe::/16 comment="defconf: 6bone" list=bad_ipv6
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ipv6 firewall filter add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
/ipv6 firewall filter add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 firewall filter add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" connection-state=established,related
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ipv6 firewall filter add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
/ipv6 firewall filter add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
/ipv6 firewall filter add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
/ipv6 firewall filter add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept HIP" protocol=139
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
/ipv6 firewall filter add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock set time-zone-name=America/New_York
/system ntp client set enabled=yes
/system ntp client servers add address=time.google.com
/system routerboard mode-button set enabled=yes on-event=dark-mode
/system routerboard wps-button set enabled=yes on-event=wps-accept
/tool mac-server set allowed-interface-list=LAN
/tool mac-server mac-winbox set allowed-interface-list=LAN
Yep, though you should select the configuration you posted and hit the button </> that will make it into "code" (basically include it between three leading backticks and three ending backticks, in some cases you need to add "RouterOS" to have the code properly formatted.
I.e. (replaced backticks with apostroph):
this is code
or:
'''RouterOS
this is code
Also - for whatever reason - you export was made with the "terse" option, that makes everything less readable (but easier to copy/paste single lines).
Here it is hopefully properly converted and formatted (moved /system script at the bottom):
# 2026-06-07 05:33:06 by RouterOS 7.23.1
# software id = XXXXXXXXXX-XXXXXX
# model = XXXXXXXXXXXXXXXXXXXXX
# serial number = XXXXXXXXXXXXXXXXX
/interface wifi
/disk settings
/ip dhcp-client
# Interface not active
/ip dns static
/system clock
/system ntp client
set enabled=yes
/tool mac-server
/system script
\n } else={\r
\n }\r
\n "
\n "
Well, damn. It works perfectly now. Was I even close with my initial config or was it your magic with the added lines of code on the end of the config file?
Maybe you just rebooted the device, point #23:
or - sometimes it happens - it is just voodoo.
Your wifi settings are still (IMHO) a mess, they should be reviewed and re-organized along the DRY principle:
https://en.wikipedia.org/wiki/Don't_repeat_yourself
You should use one (or two in your case) configuration and security settings and two channels and leave the radios in /interface wifi set with just a configuration, a security and a channel.
Check the example given here:
It is more readable compared to have settings spread here and there, in any case use "print detail" and "print detail config" to see the whole settings applied to each interface.
Thank you all for the help, advice, and suggestions. I really appreciate everyone taking the time to point me in the right direction.
I'm up and running now, and I'll be reviewing the WiFi settings to clean things up a bit. I have noticed one issue: when I connect Starlink to port 1, I occasionally have to disable wifi2 and then unplug/reconnect my laptop on one of the LAN ports (2-5) before internet access starts working properly. That tells me there is probably still some tweaking to do with the failover configuration.
That said, the setup is completely usable at this point and is doing what I need it to do. I'll continue fine-tuning it as I learn more about MikroTik.
Thanks again for all the assistance, and I hope everyone enjoys the rest of their weekend!
Well, the configuration you posted has no provisions for failover (no recursive routes, nor netwatch scripts), if you have issues, once things have "stabilized" a little, post again your current configuration and surely someone will be able to find the issue.
I cleaned up the WiFi configuration and profiles a lot. I also have failover working now but not using Netwatch ……yet. Probably a poor man’s failover for now but it works nonetheless.
