hi there, I am new at MT, i have a pc, MT installed on it, so it acts now as a router. My question is how do I use now this router as an Access point, do I need another pc for this or should i use the same pc that runs mikrotik (router)… and how many interfaces do i need and which kind of cards, thnx for advance.
All you need is the WISP AP (Level 4) license , PCI to MiniPCI adapter, miniPCI radio wand pigtail.
(IA/MP1R) RouterBOARD 11 MiniPCI Adapter with bracket for RPTNC
(R52) 802.11a+b+g 65 mW Wireless miniPCI Card
(AC/UFL) U.fl-HIROSE’S Nfemale pigtail cable
Also make sure you have the wireless package installed by looking in system /packages. If it’s not installed just select it then click install and reboot.
also you probably need some time to read the manual.
regards,
C. G.
