i have 2 mpci senao 400mw and 2 mpci aircord 200mw
both of them a/b/g
i installed them in two RB112
with aircord Power injector 48v also pigtai
as i see people over here always asking about heat and power problems
i think in my case the power was very very stable i keep the board running all the night i noticed the following
senao gets heat littel more than aircord one “but its still arround 40c”
aircord the speed locked to 24 mbps and 23db of output power
senao the speed locked to 24mbps and 26db of output power
anyone intersted into those boards just ask me about any technical detials
regarding how to incress the output power
for me it works as follow
i choose my country
i also chose munal tx power
then u should ues Card rate to 26 u will see big diffrents but normally it takes arround 10 secounds in senao to noticed the diffrent in the client
2ghz-5mhz and 10 mhz works between both aircord and senao mini-pci
5ghz-5mhz and 10 mhz not working between those 2 cards
aircord frequancy range 5120-58XX the senao 5180-58XX
update # 3
the senao card doesnt support compression any idea guys??
also it have more noise floor than regular cards
i m getting -101 in aircord and -96 to -98 on senao exactly the same location and same routerboard also same pci slot
is it not supported by MT??
