Hi I have a very simple question. I use the Ltap LTE6 on my boat for internet access.
I use a sim with unlimited data. But, when 10Gb is reached, the provider sends a sms, using that sms i can add additional data.
In just want to receive these SMSs in my Inbox.
The problem is, that I do not get any incoming sms.
Using the app, Advanced Settings, Tools, SMS, SMS, I set:
Receive enabled : yes
LTE interface lte1
I tried leaving Secret and Allowed numbers empty → no incoming SMS
Then I set secret to “test” and added my mobile as Allowed number → no incoming SMS
That’s a rather important piece of info you failed to mention the first time.
You never even mentioned what device you have, which version it currently uses, …
Downgrade then if it worked before and make support ticket with all required info so it can be investigated.
I understand you don’t want to provide your config but don’t expect anyone to be able to help in an efficient way then.
This is a user forum. Users helping other users.
Maybe it is just coincidence that issue appeared after ROS update because number of SMS messages stored on SIM reached limit, check this: https://help.mikrotik.com/docs/display/ROS/SMS
keep-max-sms (integer; Default: 0) Maximum number of messages that will be saved. If you set this bigger than SIM supports, new messages will not be received. Replaced with auto-erase parameter starting from RouterOS v6.44.6
If that is the issue, delete old messages in Inbox and set config keep-max-sms to some number below max number allowed by SIM storage. 10 can be safe unless you want more history. If is set to 0 (Default), same as replaced config auto-erase=no, can cause full SIM inbox if messages are not manually deleted and new messages will not be received:
SIM storage size is read automatically. When auto-erase=no new SMS will not be received if storage is full. Set auto-erase=yes to delete the oldest received SMS to free space for new ones automatically. Available starting from v6.44.6
had the same problem on an Ltap_2HnD (ROS 7.16.1 and 7.16.2)
It appeared that the setting SMS setting polling was default set to no, when I changed it to yes SMS messages were actually received. The setting survives reboot, not sure if it survives a ROS upgrade.
