Hello, I’m just learning so all hints about the current configuration welcome
I’m learning how to do Vlans and overall I think I’ve configured everything the way I’d like, I have vlan 30 and I’d like it to be something like a DMZ zone. I have separated a file server and a private web server into this vlan. Unfortunately both servers do not have internet access. How would you guys be able to advise what to improve / fix in my configuration I would be very grateful. Device is hAP ax3
add admin-mac=78:9A:18:36:14:DF auto-mac=no comment=defconf name=bridge vlan-filtering=yes
set [ find default-name=ether3 ] rx-flow-control=auto tx-flow-control=auto
/interface wifiwave2
set [ find default-name=wifi2 ] channel.band=2ghz-n .skip-dfs-channels=10min-cac .width=20/40mhz configuration.country=Poland \
.mode=ap .ssid=UberNet disabled=no security.authentication-types=wpa2-psk,wpa3-psk
add configuration.hide-ssid=no .mode=ap .ssid=UberNetIoT disabled=no mac-address=7A:9A:18:36:14:E5 master-interface=wifi2 name=\
"wifi2 IoT" security.authentication-types=wpa2-psk
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.country=Poland \
.mode=ap .ssid=UberNet5 disabled=no name=wifi5 security.authentication-types=wpa2-psk,wpa3-psk
/interface vlan
add interface=bridge name="vlan20 - iot" vlan-id=20
add interface=bridge name="vlan30 - dorsz" vlan-id=30
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=DmZ
add name="DHCP IoT" ranges=192.168.20.2-192.168.20.254
add name=dhcp_pool2 ranges=192.168.30.2-192.168.30.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add address-pool="DHCP IoT" interface="vlan20 - iot" name=dhcp1-Iot
add address-pool=dhcp_pool2 interface="vlan30 - dorsz" name=dhcp1
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether2
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=30
add bridge=bridge comment=defconf interface=ether4 pvid=20
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether5 pvid=30
add bridge=bridge comment=defconf interface=wifi5
add bridge=bridge comment=defconf interface=wifi2
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface="wifi2 IoT" pvid=20
/interface bridge vlan
add bridge=bridge tagged=bridge vlan-ids=20
add bridge=bridge tagged=bridge vlan-ids=30
add disabled=yes interface="vlan30 - dorsz" list=DmZ
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.20.1/24 interface="vlan20 - iot" network=192.168.20.0
add address=192.168.3.1/24 disabled=yes interface=*D network=192.168.3.0
add address=192.168.30.1/24 interface="vlan30 - dorsz" network=192.168.30.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.224 client-id=1:a8:86:dd:b5:17:cd mac-address=A8:86:DD:B5:17:CD server=defconf
add address=192.168.88.111 client-id=1:a8:a1:59:ee:4f:cc mac-address=A8:A1:59:EE:4F:CC server=defconf
add address=192.168.20.3 mac-address=C8:2B:96:54:48:3C server=dhcp1-Iot
add address=192.168.20.4 mac-address=84:0D:8E:77:41:8B server=dhcp1-Iot
add address=192.168.20.6 client-id=1:0:80:64:df:c4:1e mac-address=00:80:64:DF:C4:1E server=dhcp1-Iot
add address=192.168.20.2 mac-address=C4:4F:33:B3:97:76 server=dhcp1-Iot
add address=192.168.20.7 mac-address=2C:F4:32:AA:A2:0F server=dhcp1-Iot
add address=192.168.20.8 mac-address=FC:F5:C4:86:FA:B9 server=dhcp1-Iot
add address=192.168.20.9 mac-address=50:02:91:B8:60:FA server=dhcp1-Iot
add address=192.168.30.2 client-id=1:0:11:32:40:51:4c mac-address=00:11:32:40:51:4C server=dhcp1
add address=192.168.30.3 client-id=ff:bc:92:b3:ba:0:2:0:0:ab:11:3c:51:6a:14:85:56:c4:2 mac-address=DC:A6:32:7F:A1:E5 server=dhcp1
add address=192.168.20.0/24 comment=IoT dns-server=192.168.20.1 gateway=192.168.20.1
add address=192.168.30.0/24 gateway=192.168.30.1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=forward comment="Vlan port forwarding" connection-nat-state="" disabled=yes dst-address=192.168.30.0/24 \
in-interface-list=WAN protocol=tcp
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
add action=masquerade chain=srcnat comment="Vlan 30 internet access" out-interface="vlan30 - dorsz"
add action=dst-nat chain=dstnat comment="Minecraft server forward" dst-port=24465 protocol=tcp to-addresses=192.168.30.3 to-ports=\
24465
add action=dst-nat chain=dstnat comment="Dorsz Drive" dst-port=6690 protocol=tcp to-addresses=192.168.30.2 to-ports=6690
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=\
fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Warsaw
/system note
set show-at-login=no
/system package update
set channel=long-term
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=ether3
