No-Ip script Solved
Can somebody help me im using these script on 6.18 and its not working…
im on NAT
#No-IP automatic Dynamic DNS update for RouterOS v6.x
#--------------- Change Values in this section to match your setup ------------------
# No-IP User account info
:local noipuser "MY-EMAIL@gmail.com"
:local noippass "MY-PASSWORD"
# Set the hostname or label of network to be updated.
# Hostnames with spaces are unsupported. Replace the value in the quotations below with your host names.
# To specify multiple hosts, separate them with commas.
:local noiphost "MY-HOSTNAME.noip.me"
# Change to the name of interface that gets the dynamic IP address
:local inetinterface "YOUR_WAN_INTERFACE_NAME_f.e_port2_public"
# No more changes need
:global previousIP
:if ([/interface get $inetinterface value-name=running]) do={
# The update URL. Note the "\3F" is hex for question mark (?). Required since ? is a special character in commands.
       :local url "http://dynupdate.no-ip.com/nic/update\3F"
       :local noiphostarray
       :set noiphostarray [:toarray $noiphost]
       :foreach host in=$noiphostarray do={
           :log info "No-IP: Sending update for $host"
           /tool fetch url=($url . "&hostname=$host") user=$noipuser password=$noippass mode=http keep-result=no;
           :log info "No-IP: Host $host updated on No-IP with IP $currentIP"
} else={
   :log info "No-IP: $inetinterface is not currently running, so therefore will not update."
Some search first?
http://forum.mikrotik.com/t/ddns-script-for-no-ip-dyndns-ipchange/79060/2
About the script you post are some errors, the biggest are “\3F” and are described why on another post.
