Hi All
We recently purchased a new CCR2216-1G-12XS-2XQ and I am having trouble bring up the link between the device and two of our existing Cisco Nexus 3064-X devices. On the CCR side I am using both the QSFP28 interfaces to connect to the QSFP+ interfaces on the Nexus. I am also using 40G DAC cables from FS.com and I specified the encoding for each end of the cable. Before returning the cables I would like to rule out any misconfiguration on my end, which I assume is most likely the case. I am still new to Mikrotik and I was told that to bring the connection up I should only enable one of the interfaces and manually set the speed to 40Gbps but still no luck. Please see some of my configuration below
/interface export
# aug/16/2022 17:06:43 by RouterOS 7.4.1
# software id = I2YE-4LIK
# model = CCR2216-1G-12XS-2XQ
add name=bridge1
set [ find default-name=qsfp28-1-1 ] auto-negotiation=no comment=\
"To nexus-1 Eth1/49" speed=40Gbps
set [ find default-name=qsfp28-1-2 ] disabled=yes
set [ find default-name=qsfp28-1-3 ] disabled=yes
set [ find default-name=qsfp28-1-4 ] disabled=yes
set [ find default-name=qsfp28-2-1 ] auto-negotiation=no comment=\
"To nexus-2 Eth1/49" speed=40Gbps
set [ find default-name=qsfp28-2-2 ] disabled=yes
set [ find default-name=qsfp28-2-3 ] disabled=yes
set [ find default-name=qsfp28-2-4 ] disabled=yes
set [ find default-name=sfp28-1 ] comment="To nexus-1 Eth1/17"
set [ find default-name=sfp28-2 ] comment="To nexus-1 Eth1/18"
set [ find default-name=sfp28-11 ] comment="To ccr-2 on sfp28-11"
add name=WAN
add name=LAN
add bridge=bridge1 interface=qsfp28-1-1
add bridge=bridge1 interface=qsfp28-1-2
add bridge=bridge1 interface=qsfp28-1-3
add bridge=bridge1 interface=qsfp28-1-4
add bridge=bridge1 interface=qsfp28-2-1
add bridge=bridge1 interface=qsfp28-2-2
add bridge=bridge1 interface=qsfp28-2-3
add bridge=bridge1 interface=qsfp28-2-4
add bridge=bridge1 interface=sfp28-1
add bridge=bridge1 interface=sfp28-2
add bridge=bridge1 interface=sfp28-3
add bridge=bridge1 interface=sfp28-4
add bridge=bridge1 interface=sfp28-5
add bridge=bridge1 interface=sfp28-6
add bridge=bridge1 interface=sfp28-7
add bridge=bridge1 interface=sfp28-8
add bridge=bridge1 interface=sfp28-9
add bridge=bridge1 interface=sfp28-10
add bridge=bridge1 interface=sfp28-11
add bridge=bridge1 interface=sfp28-12
add interface=ether1 list=WAN
add interface=qsfp28-1-1 list=LAN
add interface=qsfp28-1-2 list=LAN
add interface=qsfp28-1-3 list=LAN
add interface=qsfp28-1-4 list=LAN
add interface=qsfp28-2-1 list=LAN
add interface=qsfp28-2-2 list=LAN
add interface=qsfp28-2-3 list=LAN
add interface=qsfp28-2-4 list=LAN
add interface=sfp28-1 list=LAN
add interface=sfp28-2 list=LAN
add interface=sfp28-3 list=LAN
add interface=sfp28-4 list=LAN
add interface=sfp28-5 list=LAN
add interface=sfp28-6 list=LAN
add interface=sfp28-7 list=LAN
add interface=sfp28-8 list=LAN
add interface=sfp28-9 list=LAN
add interface=sfp28-10 list=LAN
add interface=sfp28-11 list=LAN
add interface=sfp28-12 list=LAN
