I used all method here with no luck , Ultrasurf and Hotspot Shield working
I have MT 5.20
is there any help ???
get a rabbit leg?
But. seriously. You need to tell something more. As far as I know from your post. You need to fist plug power to the device.
Try to tell a bit more about the problem.
