Hello everyone. After a couple months of frustration and clicking through every article I can find on using NordVPN with my MT, I’ve finally broken down to try and get some help. It seems like no matter what I do, my NordVPN connection pegs at 20 meg (on a good day). I’ve tried fasttrack, mangle rules, setting the whole thing up again, and my laptop is about to get flying lessons due to the frustration. Can someone take a look at the following config and see if there is something blatantly stupid I’m missing?
Thanks!
export hide-sensitive
# 2023-10-02 21:41:57 by RouterOS 7.10.2
# software id = GTKA-36XW
# model = RB2011iL
# serial number = <removed>
set [ find default-name=ether2 ] name=CHIPPERNET
set [ find default-name=ether5 ] name=IOT
set [ find default-name=ether1 ] name=LUMEN
set [ find default-name=ether3 ] name=STEMP
set [ find default-name=ether4 ] name=TV
/interface virtual-ethernet
add arp=enabled disabled=yes mac-address=02:00:28:58:DA:81 mtu=1500 name="test eth"
/interface vlan
add interface=ether8 name=vlan1 vlan-id=80
add interface=ether8 name=vlan2 vlan-id=85
add name=WAN
add name=LAN
/interface lte apn
/ip ipsec mode-config
add name=NordVPN responder=no src-address-list=TV
/ip ipsec peer
add address=<redacted> exchange-mode=ike2 name=CABIN
/ip ipsec policy group
add name=NordVPN
/ip ipsec profile
set [ find default=yes ] hash-algorithm=sha256
add name=NordVPN
/ip ipsec peer
add address=us5938.nordvpn.com exchange-mode=ike2 name=NordVPN profile=NordVPN
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-cbc
add name=NordVPN pfs-group=none
add name=CHIPPERNET-dhcp ranges=10.0.20.30-10.0.20.254
add comment=TV name=TV-dhcp ranges=10.0.100.10-10.0.100.100
add comment=IOT name=IOT-dhcp ranges=10.0.50.10-10.0.50.100
add address-pool=CHIPPERNET-dhcp interface=CHIPPERNET lease-time=10m name=dhcp1
add address-pool=TV-dhcp interface=TV name=dhcp2
add address-pool=IOT-dhcp interface=IOT lease-time=10m name=dhcp3
/port
set 0 name=serial0
/routing table
add fib name=nordvpn_blackhole
/snmp community
add addresses=::/0 name=zabbix
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface detect-internet
set detect-interface-list=all wan-interface-list=all
add independent-learning=no ports=STEMP switch=switch1 vlan-id=101
add interface=LUMEN list=WAN
add interface=CHIPPERNET list=LAN
add interface=IOT list=LAN
add interface=vlan1 list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=10.0.20.1/24 interface=CHIPPERNET network=10.0.20.0
add address=10.1.0.1/25 interface=STEMP network=10.1.0.0
add address=10.0.100.1/25 comment=TV interface=TV network=10.0.100.0
add address=10.0.50.1/25 interface=IOT network=10.0.50.0
add address=10.0.0.10/24 interface=ether9 network=10.0.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=16m40s
/ip dhcp-client
add interface=LUMEN
add address=10.0.20.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=10.0.20.1 netmask=24
add address=10.0.50.0/25 dns-server=103.86.96.100,103.86.99.100,8.8.8.8,1.1.1.1 gateway=10.0.50.1
add address=10.0.100.0/25 dns-server=103.86.96.100,103.86.99.100,8.8.8.8,1.1.1.1 gateway=10.0.100.1
add address=10.1.0.0/25 dns-server=8.8.8.8,1.1.1.1 gateway=10.1.0.1
/ip firewall address-list
add address=10.0.20.0/24 list=local
add address=110.0.20.0/24 list=local
add address=10.0.50.0/25 list=localiot
add address=10.0.100.0/25 comment=TV list=TV
add action=fasttrack-connection chain=forward connection-mark=!ipsec connection-state=established,related hw-offload=\
yes
add action=accept chain=forward connection-state=established,related
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark=NordVPN passthrough=yes src-address-list=NordVPN
add action=mark-routing chain=prerouting new-routing-mark=nordvpn_blackhole passthrough=yes src-address-list=\
under_nordvpn
add action=change-mss chain=forward connection-mark=!ipsec new-mss=1360 passthrough=yes protocol=tcp tcp-flags=syn \
tcp-mss=!0-1360
add action=mark-connection chain=forward comment="Mark IPsec" ipsec-policy=out,ipsec new-connection-mark=ipsec
add action=mark-connection chain=forward comment="Mark IPsec" ipsec-policy=in,ipsec new-connection-mark=ipsec
add action=dst-nat chain=dstnat comment=SONARR disabled=yes dst-port=7878 in-interface=LUMEN protocol=tcp to-addresses=\
10.0.20.12 to-ports=7878
add action=dst-nat chain=dstnat comment=NAS disabled=yes dst-port=9443 protocol=tcp to-addresses=10.0.20.5 to-ports=\
9443
add action=dst-nat chain=dstnat comment="PLEX REMOTE ACC" dst-port=32400 protocol=tcp to-addresses=10.0.20.12 to-ports=\
32400
add action=dst-nat chain=dstnat comment="REMOTE DESKTOP" disabled=yes dst-port=3389 protocol=tcp to-addresses=\
10.0.20.20 to-ports=3389
add action=dst-nat chain=dstnat comment=OMBI-Requests dst-port=3579 protocol=tcp to-addresses=10.0.20.12 to-ports=3579
add action=dst-nat chain=dstnat comment=ZABBIX dst-port=10064 protocol=tcp to-addresses=10.0.20.64 to-ports=80
add action=dst-nat chain=dstnat comment=LIDARR disabled=yes dst-port=7878 protocol=tcp to-addresses=10.0.20.12 \
to-ports=7878
add action=masquerade chain=srcnat comment="VPN NETWORK" out-interface=LUMEN src-address=10.0.100.0/25
add action=dst-nat chain=dstnat comment=NZBGET disabled=yes dst-port=6789 log-prefix="\"\"" protocol=tcp to-addresses=\
10.0.20.12 to-ports=6789
add action=dst-nat chain=dstnat comment=nginx-http dst-address=!10.0.20.1 dst-address-type=local dst-port=80 protocol=\
tcp to-addresses=10.0.20.12 to-ports=80
add action=dst-nat chain=dstnat comment=nginx-https dst-address=!10.0.20.1 dst-address-type=local dst-port=443 \
protocol=tcp to-addresses=10.0.20.12 to-ports=443
add action=masquerade chain=srcnat comment=nginx-hairpin-nat dst-address=10.0.20.12 dst-port=80,443 protocol=tcp
/ip firewall service-port
set h323 disabled=yes
set sip disabled=yes
/ip ipsec identity
add peer=CABIN
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=NordVPN peer=\
NordVPN policy-template-group=NordVPN username=<redacted>
/ip ipsec policy
add dst-address=0.0.0.0/0 group=NordVPN proposal=NordVPN src-address=0.0.0.0/0 template=yes
set 1 dst-address=10.0.0.0/24 src-address=10.0.20.0/25
add disabled=yes dst-address=0.0.0.0/0 gateway="test eth" routing-table=nordvpn_blackhole
/ip service
set telnet address=10.0.20.0/24 disabled=yes port=2300
set ftp disabled=yes
set www address=<redacted>
set ssh address=<redacted>
set api disabled=yes
set winbox address=<redacted>
set api-ssl disabled=yes
/ip traffic-flow
set enabled=yes interfaces=LUMEN
/routing bfd configuration
add disabled=no
/snmp
set enabled=yes
/system clock
set time-zone-name=America/New_York
/system identity
set name=CHIPPERNET-RTR
/system note
set show-at-login=no
/system ntp server
set enabled=yes
