My problem is that i cant connect to the hotspot and access the internet when i enable wep security on the router. The network cards connect to my ap’s “senao” but i dont get an ip from the router anymore. If i disable wep throught the devices it works again. Hmm im tired…
I believe you will need your data to be unencrypted from WEP before any address negotiations will work, as the client is not able to do any IP communications on a WEP encrypted stream. You will have to make sure that WEP is properly configured on both the router/AP and the client radio, and that both ends are being supplied with matching keys by some means of your choosing.
Hitek
EDIT: Yes, this means that all of your Hotspot customers would have to be supplied with a key somehow, and this would somewhat defeat any small advantage that you already had when using WEP.
x-posting the answer to this. It will not work if you’re using orinoco silver/gold wireless cards (and possibly other hermes chipset based cards. Try using something Prism based.
