nRAYG-60ad failed to upgrade from 7.13.4 to 7.17.2, 7.18.2, 7.19.2
After the update, the device ends up in the NetConfig boot loop.
I’ve tried it on multiple devices with default config.
7.13.4 → 7.19.2 - Failed
7.13.4 → 7.18.2 - Failed
7.13.4 → 7.17.2 - Failed
7.13.4 → 7.16.2 - OK
7.14.3 → 7.19.2 - OK
7.15.3 → 7.19.2 - OK
Might be useful to create support ticket with your findings.
I’ve already done that as SUP-192053. I just wanted to let the community know.
Support response:
I am able to confirm that the issue exists unfortunately.
This issue was fixed in later versions. Currently we do not have solution for those who are still on the faulty version. You could gradually upgrade RouterOS to non-faulty version and stable afterwards and later on you shouldn’t have issues with this. We are still investigating how we could fix this issue for those who already have the faulty version installed.
Thanks for sharing !
