mortin
December 19, 2006, 12:25pm
1
Some time ago I read on mikrotik manuall that there is no way to bridge the nstreme dual connection.
I found test results of rb112:
http://www.mikrotik.com/download/rb112test.pdf
There is a results
“Nstreme DUAL between RB112 conn-track enabled, bridging !!”
I have never tried to bridge the dual nstreme.
Is it possible ?
Simple nstreme works great in bridge with wds.
Regards
Marcin
normis
December 19, 2006, 12:29pm
2
you can use bridging in nstreme2. can you point me to the spot in the manual where it says that you can’t ?
sergejs
December 19, 2006, 12:41pm
3
Bridge does not equal to WDS. WDS links is not possible on Dual Nstreme links, however bridge on the Dual Nstreme link should work fine.
mortin
December 19, 2006, 12:58pm
4
Upss … I read it wrongly.
There is only information about using WDS.
“WDS cannot be used together with the Nstreme-dual”
[/url][http://www.mikrotik.com/testdocs/ros/2.9/interface/wireless.php[url](http://www.mikrotik.com/testdocs/ros/2.9/interface/wireless.php[url) ]
It is a great news to me !
Currenlty I have the following situation:
network === ap(p4) —simple nstreme with wds bridged —ap(p4)=== network.
So I can change it easly and save the bridge between the networks.
Regards
Marcin
