Hi …
Sorry, the pictured was reduced in size to fit the html page with minimum scrolling.
The blue area is not minimum but maximum. And yes, shows power peak. As 802.11-not-N modes are half duplex this filled area tooks some time to build up because the test equipment scans full spectrum ~4 times per second. So the chance to it be “listening” exactly the frequency where 802.11 signal is are small. Several scans are necessary to integrate existing power at certain portion of the analyzed spectrum.
The green line - average - seems like noise floor due to test equipment sampling method. May be NV2 have this “hump” at the - useless for me - average line due to the 2 miliseconds bursts, against 25 microseconds from regular 802.11 half-duplex. So the test equipment have more energy sampled per period of time (see, it’s a Us$ 50 USB device, not a HP or R&S +15k Us$ with the plugin firmware to 802.11 modes lol).
The yellow line is the current sampled signal amplitude. Useless to TDM/TDMA modes but usefull to “watch” some narrow band signal such as cordless phones, steady carriers, local oscilator leaks & etc.
Hmmm … this is an off-air sample, both ~20dBm … different antennas. The correct analisis should be done in a different way, both radios connected to a 2 way splitter/combiner with > 60dB port isolation and the common port connected to the spectrum analyzer. And - again - I guess the peaks on NV2 are introduced by some limitations the test equipment. Unless MT is using 4 of 54 OFDM carriers as pilots or something like that.
The total power is the same … but G modes keep the energy restricted to its 52 (or 54, I don’t remember) carriers. B mode have a single carrier spreaded in the spectrum. Since power is proportional to the filled area, the RMS value match but the peak value will be different (802.11B spreads a bit more).
Anyway, the ony thing I try to show on such pictures is that the “G” modes spectrum use are pretty the same. Received power is ~60dBm while intermod products are below -25dBc (e.g less than -85dBm).
Now, if second card front end does not handle vy well existing power from the first one, all intermod products will raise at this card, due to RX low noise amp / mixer overload. But the irradiated spectrum mask is what the pictures are showing.
Regards;
