I am doing nth load balancing on a MK450G. I have a DSL + Cable internet connection both with dynamic ip.
The load balace is workng but I see much more odd than even connections. As a result I have more traffic on one interface and very little on the other.
Please give me some advise.
/ip firewall export
mar/09/2011 20:58:24 by RouterOS 4.17
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s
tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m
udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
/ip firewall mangle
add action=mark-connection chain=prerouting comment="" disabled=no in-interface=bridge1 new-connection-mark=odd passthrough=yes src-address-list=odd
add action=mark-routing chain=prerouting comment="" disabled=no in-interface=bridge1 new-routing-mark=odd passthrough=no src-address-list=odd
add action=mark-connection chain=prerouting comment="" disabled=no in-interface=bridge1 new-connection-mark=even passthrough=yes src-address-list=even
add action=mark-routing chain=prerouting comment="" disabled=no in-interface=bridge1 new-routing-mark=even passthrough=no src-address-list=even
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no in-interface=bridge1 new-connection-mark=odd nth=2,1 passthrough=yes
add action=add-src-to-address-list address-list=odd address-list-timeout=1d chain=prerouting comment="" connection-mark=odd disabled=no in-interface=bridge1
add action=mark-routing chain=prerouting comment="" connection-mark=odd disabled=no in-interface=bridge1 new-routing-mark=odd passthrough=no
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no in-interface=bridge1 new-connection-mark=even nth=2,2 passthrough=
yes
add action=add-src-to-address-list address-list=even address-list-timeout=1d chain=prerouting comment="" connection-mark=even disabled=no in-interface=
bridge1
add action=mark-routing chain=prerouting comment="" connection-mark=even disabled=no in-interface=bridge1 new-routing-mark=even passthrough=no
add action=masquerade chain=srcnat comment="" disabled=no out-interface=pppoe1
add action=masquerade chain=srcnat comment="" disabled=no out-interface=ether1
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=5900 in-interface=ether1 protocol=tcp to-addresses=10.0.0.245 to-ports=5900
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=5900 in-interface=pppoe1 protocol=tcp to-addresses=10.0.0.245 to-ports=5900
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
