NTP Client not synchronizing
Hi.
system ntp client print
enabled: yes
mode: unicast
primary-ntp: 216.239.35.0
secondary-ntp: 216.239.35.4
dynamic-servers:
status: started
Not synchronized, NO FW rules! No helps reboot. Not helps change ntp servers.
system routerboard print
routerboard: yes
model: 2011iL
serial-number: 607Exxx
firmware-type: ar9344
factory-firmware: 3.22
current-firmware: 3.41
upgrade-firmware: 3.41
system package print
Flags: X - disabled
NAME VERSION SCHEDULED
0 system 6.40.8
1 security 6.40.8
2 ppp 6.40.8
3 ntp 6.40.8
4 dhcp 6.40.8
5 advanced-tools 6.40.8
Capture all ntp:
ip firewall filter print
0 chain=forward action=accept protocol=udp dst-port=123 log=yes log-prefix=""
1 chain=input action=accept protocol=udp src-port=123 log=yes log-prefix=""
2 chain=output action=accept protocol=udp dst-port=123 log=yes log-prefix=""
3 chain=forward action=accept protocol=udp src-port=123 log=yes log-prefix=""
Only output and forward (nat windows) NTP traffic... No input. (
Is it possible HW issue? WTF???
Waiting info from ISP, possibble ISP issue. The same problem with IP cams (mikrotik nat).
