Hello, i’m missing ntp-server on my routerboard 2011 UAS-RM
RouterOS 6.13rc13
I’m missing that on RouterOs 6.12 also.
How can i add ntp-server?
As manual:
http://wiki.mikrotik.com/wiki/Manual:System/Time#SNTP_client
SNTP client is included in the system package.
NTP server and a NTP client is included in the separate ntp package, that is not installed by default.
Thanks this means downgrade to 6.12
Have you tried just to add ntp 6.12 package from all_packages-mipsbe-6.12.zip ?
yes but that don’t work
Sorry, I didn’t see the your version first.
On mikrotiks own demo sites i can se the ntp package also missing.
You have to download the “all packages” file and then manually install the ntp npk.. It’s not in there by default any more.
plisken and I can’t find the all package zip file for the release candidate version.
RouterOS 6.13rc13
It is on the support website under development version releases. I’m grabbing it now just to make sure the ntp file is in there…
EDIT: It is.
Gr8. You solve the problem.
Greate Efaden thanks for your sugestion!!!
