Dear Guys !
The Wireless Interface use nv2 protocol mode but dont show the security profile, i change the protocol mode to nv2-nstream the secure profile show again. Any idea ? Ros 6.41.2
Regards
Krisztian
Dear Guys !
Regards
Krisztian
Other Solution ? New Version bugfix ?
Nv2 has his own security function direkt unter Nv2 Setup, if you select Nv2 as Protocol the security profile is not used!
This isn’t new!
https://wiki.mikrotik.com/wiki/Manual:Nv2#Security_in_Nv2_network
Not good song, if you use radius authentication the wlan interface not working nv2 only nv2-nstreme mode. The NV2-security can not use security profile !!
Dear Mikrotik, Please bugfix.
Nv2 security can’t be used with RADIUS auth.
Whay ? Before v 6.40 version working perfect !!!
Same problem here.
Older versions works perfect with nv2+radius.
same problem with “long-term” release 6.42.10.
The problem is that the security-profile must be specified if it works with radius authentication even if nv2 uses its own “security”.
Up.
Some plans to introduce NV2 compatibility with 802.1x and radius in ROS 7?
