RB711-5Hn, 26dBi Pac wireless grid, 3ft LMR 400, 14 miles connecting to an XR5 + 12dBi omni.
One of my newer towers, hasn’t been upgraded to a dedicated ptp shot yet. signal was around -75, close to -83 during really nasty weather.
It went deaf early Saturday morning. I got a backup going until I could get the equipment swapped out. I log in this morning and the 711 has connected to the main AP. I do a scan and it can’t see the AP, then loses everything again.
Didn’t see the local 5GHz AP Saturday, now it doesn’t see anything, . Does this sound more like water in the cable or a fried board?
I had a simular problem with RB433Ah and R52 card. I replaced the dish and lmr 400 still had bad signal. could not see any radio in scan mode even other radio on tower. But the other side could see it. Turned out that the RX side of the R52 went bad. I replaced the card got it working then later reinstalled the dish. The grid I had sub did not have a good signal.
So could be water in cable but knowing you as a long time ISP I am sure you water proofed your N connectors. So maybe radio and since the RB711 has the radio built in I guess replace whole RB711 board.
Good luck let me know what it was. It is good to have feed back.
Just got around 2 inches of rain and the temp went from 80F to 48F with pretty decent winds, a weaker storm with very similar conditions to the other night, link is still going strong.
Rained and rained, cold and windy, worked fine for days. Light drizzle this morning, link went down and won’t come back up.
It has to be moisture or something. As soon as my climber is ready I’ve got another antenna, cable and extra MT hardware just in case. Considering the link worked perfectly for days then died again after rain it has to be weather related.
I doubt it is that obvious. I’ve been doing this for a few years now.
I have had a few cables come apart where the N type connector was crimped to the cable. Free replacement of a $15 cable isn’t worth much. I need to buy my own kit and make them myself.
