i m using Omnitik but it is not working in 360 degree when i was connect 3rd from other (All radio r other different location in 1.5 km round area) loacation ,it is opp. Omnitik that time it 's connectivity is very bad,
omnitik radio need require elighment??(i think no require)???
you will have the best signal if you point directly at the front of the omnitik unit (because of the antenna pattern), and also the best gain of the omnitik antenna is in 5.4GHz. try to rotate the omnitik unit, so that it’s directly facing the client device, and your signal will be better. also try to change from 5.8 to 5.4GHz
