That is the issue of 4 wheels drive and 2 wheels drive. Everything as got its own purpose. If you need to have external antenna port you can just assemble routerboards to meet your purpose.
If you need to install antennas at high tower and you do not what to run cables this product is not for you. Just assemble routerboards.
For the pole mount at rooftop, my cable runs are only 4 to 6 meters from my power backup. So I can easy run as may cables as I want.
To me this device is well designed. I real like to know the performance in real life.
If you don’t like MikroTik products, simply use Ubiquiti ones and stop insulting them without any good argument. As Normis said more than once - it’s hard to please everyone and it’s not possible.
I ask, in what state is the most customers? I am an ISP from the Czech Republic and here is something like omnitik not applicable. Interference can not use omnitik. Omnidirectional antenna is useless here in the cities.
I am a big supporter of Mikrotik, but what it lately Mikrotik does is bad. He does everything so that more people switched to Ubiquity. Here is sold 2-3x more Ubiquiti devices than Mikrotik. Dual RB711 do not get one, even if it’s a lot ran the sale.
@Hapi: I agree with You that Ubiquiti “stole” many MikroTik customers but as I hear from people… Nv2 is more polished than AirMax protocol. Also RouterOS cannot be compared to AirOS.
OmniTik looks promising. 7.5 dBi bunny ears antennas will be good for small base station (micro cell). I think that long range base stations are gone these days. Micro cells with high throughput or long range with smaller speeds.
Update:
Sorry, but interference in your city is not MikroTik fault… Others will use it. Sorry it won’t fit you.
NV2 protocol of MT is best as compared to AIROS. I had a site with very high interference where rocket5 with sector of 16db did not manage to connect my Nano CPEs. I used to switch from TDMA to 802 with no success.
Later I installed MT with omni of 7.5dbi NV2. The site is very stable for almost 6 months. As far as I know, NV2 works like Canopy. You would be better off if you use NV2 for the site that has high interference
Ubiquiti got backlogs with their devices due to high demand..so I’m looking for alternatives. Mikrotik is the best candidate but some of its product are not well executed.
I do prefer the technology of Mikrotik…it’s a class of it’s own. The only issue is that.. most end user are just satisfied with technology that works even with minor inconvenience.
I guess you know KISS..Ubiquiti got this and that is my good argument.
For a single link/AP. But as Wisp I need some additional routers with
advanced features. Using MT I have one OS that fits them all. This
does simplify things a lot. We moved from a cisco/proxim mix to
a complete MT solution. We do mix other eqipment in where MT cant
do the job. But this are things (licensed links, 5,8ghz etsi, wimax)
that cant be done with Ubiquity either. So using Ubiquity wouldn’t
simplify anything here.
Wirelessguy1
In your opinion.
UBNT has a very very limited feature set.
What does UBNT Offer you that MT Cant? More integrated solutions? Simple Ui? What?
Microcells r excellent for us to reach out every corner. We have a good OFC Mesh in around 5km radius but still we find it hard to pull cables to every home.
Ominitik is the solution… We are using 411ah with externally connected omni’s and now a complete package like ominitk would help us resolve lot of integration work.
I am looking at the Omnitik. The radio says the folloowing:
Wireless:
IEEE802.11a/b/g wireless client and access point
Full IEEE802.11n support
Nstreme and Nstreme2 proprietary protocols
NV2 protocol
Wireless Distribution System (WDS)
Virtual AP
WEP, WPA, WPA2
Access control list
Wireless client roaming
WMM
HWMP+ Wireless MESH protocol
MME wireless routing protocol
Ok, So does this mean that if I put this as a hotspot I will be able to have all types of clients connect? I done understand if its a 5ghz how does it transmit to a 802.11 b? I need to know if this is true because am about to kick Ubiquiti to the curb and looking for a city wide solution. I am already using MT as my main access controler “No Wireless”. I want to make all my network MT and I like this OmniTik a lot.. But I dont want to loose clients that dont have N or better saying use b/g devices.. Please advice since tomorrow I need to get some to send to Nicaragua…Daniel
Thanks for the response. Now Why would MT make an AP that only supports 5ghz? I think they should off made both 2.4ghz and 5ghz Omnitik. What is the point of doing this if 90% of equipment out there are not compatible with it. I been reading and even if you have b/g/n wireless card on your laptop still uses the 2.4ghz frequency, and that’s the new laptops!.. Well I guess I need to continue shopping. I needed 196 of this units but I guess there goes that Idea…
we use them as a main node router, the 4 extra ports are used to connect other devices.
We prefer using the sheaper omnitik because you can do a POE mod on the omnitik.
We don’t like to use the omnitik UPA since it has troubles powering other devices.
Last week i did some testing with modding the UPA moddel for direct poe (not switched) output.
If you need a voltage monitor you can also use the groove for 2.4 ghz clients.
