One Eth Port - 2 gateway addresses
I have 3 Vlans setup on my RB1100 with one physical port as the connection to the outside world. How can I ensure specific VLANS go out a specific Gateway?
Vlan10 192.168.10.x/24
Vlan20 192.168.20.x/24
Vlan30 192.168.30.x/24
Eth1 → Gateways (172.16.1.1/32 & 172.16.2.1/32) outside world (WWW)
What is the best configuration to ensure the following routing is acheived
Vlan10 → 0.0.0.0/0 Via 172.16.1.1/32
Vlan20&30 → 0.0.0.0/0 Via 172.16.2.1/32
  1. create static route with mark routing under /ip route.
/ip route add gateway="ip wan1" routing-mark=wan1
/ip route add gateway="ip wan2" routing-mark=wan2
  1. create rule to implement static route for your desired clients.
/ip route rule add interface=vlan10 action=lookup table=wan1
/ip route rule add interface=vlan20 action=lookup table=wan2
/ip route rule add interface=vlan30 action=lookup table=wan2
  1. check gateway for every client of vlans using tool tracert to ensure the clients get routed through the gateway as your plan.
Thanks Azma. Will try that and report back on success
Azam, is it necessary for firewall mangle rules to mark those packets? or the configuration you provide will suffice?
Applied the following codes but network not able to get out. Does NAT rules need to be updated from out-interface to the specific IP address to NAT on?
Don’t mess with routes, make src-nat rules for each of subnets like this:
add action=src-nat chain=srcnat out-interface=WAN \
    src-address=192.168.10.0/24 to-addresses=172.16.1.1/32
    src-address=192.168.20.0/24 to-addresses=172.16.2.1/32
Thanks All. The configurations listed above work as expected.
