25/tcp open smtp
110/tcp open pop3-proxy Avast! anti-virus pop3 proxy (cannot connect to 10.0.0.1)
119/tcp open nntp-proxy Avast! anti-virus NNTP proxy (cannot connect to 10.0.0.1)
143/tcp open imap-proxy Avast! anti-virus IMAP proxy (cannot connect to 10.0.0.1)
465/tcp open tcpwrapped
563/tcp open tcpwrapped
587/tcp open smtp-proxy Avast! anti-virus smtp proxy (cannot connect to 10.0.0.1)
993/tcp open tcpwrapped
995/tcp open tcpwrapped
8291/tcp open winbox MikroTik WinBox
How did those ports got open on my router and how can i close them ?
That’s not a valid scan. Avast is intercepting the nmap scan and reporting open ports, but almost all of them are not on the router .. they are local to the host.
The “proxy” ones are self evident. Another example .. tcp/563 is the Avast service itself. Google and see what the others are.
As was noted, if you are scanning from a PC within the LAN, the scan is filtered by whats going out to the LAN in accordance with the security apps on your PC and you are scanning your LAN and not the router.
If you want a more valid test of your router (not the litmus test but a reasonable test) go to grc.com.
Click on the Shields Up logo/url then after the next screen scroll down to " New Shields Up Test" (usually right after the Spinrite block).
Select proceed.
Try the file sharing selection first.
Then conduct the Common Ports
If you want you can also select specific ports or all ports (will take awhile).
Have fun!
