Open-source read-only audit of RouterOS security settings (factory defaults, CISA KEV versions)
Hi all,
I built a free, open-source tool that audits switch and router security settings, and RouterOS
support just landed (6.x and 7.x, tested on CHR 7.25.1). Sharing it here because the findings on a
factory-default RouterOS might be useful even if you never use the tool.
What it checks on a factory-default CHR 7.25.1:
  • Telnet, FTP, HTTP (WebFig) and API enabled and reachable from any address (available-from empty)
  • /ip ssh strong-crypto=no: SHA-1 key exchange and weak ciphers still offered
  • MAC-Winbox answering on every interface
  • no NTP client, no remote syslog
  • RouterOS version vs. known critical / actively exploited CVEs. Each advisory records the first
    fixed version of every release line. Example: the three RouterOS flaws CISA added to its
    Known Exploited list in September 2026 are fixed in 6.49.21, 7.23.4 (long-term) and 7.24.2
    (stable).
How it works:
  • read-only: it logs in over SSH, runs /export terse and some print terse commands, and
    logs out. It never sends show-sensitive, so secrets are not collected.
  • it works with a group that has only ssh,read (no write, no sensitive). I tested that this
    group sees everything needed and that changes are refused. Don't use the built-in read
    group: it includes sensitive.
  • it can also assess Oxidized routeros backups without logging in. Side note: on RouterOS 7,
    Oxidized stores /export show-sensitive (RADIUS secrets, SNMP passwords) unless
    remove_secret is set.
Two things I learned while testing, in case they help someone:
  • RouterOS has no SSH pre-login banner. /system note show-at-cli-login=yes shows the note before
    the console/Telnet login prompt; over SSH it appears right after login (show-at-login).
  • Exports only list non-default settings, so a missing /ip service set telnet disabled=yes
    means Telnet is still on.
Try it without touching your network. The demo simulates a small network with a
factory-default CRS326:
pip install lyss
lyss demo --open        # Windows: python -m lyss demo --open
Code and docs: GitHub - lyss-project/lyss: Open, vendor-neutral security standard for network switches + free read-only audit tool (Cisco IOS, Cisco Business, HPE Aruba). By Mouad Lyaazale, made in Morocco. · GitHub (AGPL-3.0). Least-privilege account per
platform: lyss/docs/ACCOUNTS.md at main · lyss-project/lyss · GitHub
It's a preview for RouterOS, so I'd really like feedback from real CRS/CCR/hEX devices. In
particular: wrong verdicts, outputs that differ on your version, and checks you would add.
Mouad
Wouldn't it be better the game where nothing accesses a router but the tool analyses only a copy/paste of an /export?
Good point, and LYSS already supports it. Nothing has to touch the router:
  1. On the router: /export file=router (RouterOS 7 leaves secrets out by default; on 6.x use /export hide-sensitive file=router), then download router.rsc from Files.
  2. On any PC: pip install lyss, then lyss audit --vendor mikrotik --level 2 router.rsc
It reads both the normal and the terse export. An export lists every setting that differs from the defaults, so a missing line tells you the default is still in place. That is enough to decide most checks:
  • Telnet, FTP, HTTP or API still enabled;
  • SSH strong-crypto;
  • SNMP;
  • RADIUS login;
  • remote syslog and NTP;
  • the login banner;
  • whether management sits on its own VLAN;
  • the RouterOS version against CISA's known-exploited list.
On a test router, 13 of the 20 checks are decided from the export alone.
What an export can't show: whether ports are actually up or unused, per-user idle timeouts (users aren't exported), and the RADIUS secret. Those stay "unknown"; they're never guessed.
The SSH mode is for people who want scheduled audits of many devices. It works with a group limited to ssh,read, without the sensitive policy. But the offline audit is a first-class option, and thanks for raising it: I'll make it more visible in the docs.
A follow-up, since a few things changed after this thread:
  • The offline audit is now documented: how to save the export on 6.x and 7.x, and what an export can and can't decide: lyss/docs/OFFLINE.md at main · lyss-project/lyss · GitHub
  • No install needed any more: paste the /export into https://lyss.dev/audit.html. LYSS runs entirely in the browser (Pyodide), nothing is uploaded, and the page's security policy blocks any other server.
  • --vendor is optional now. Run pip install --upgrade lyss, then lyss audit --level 2 router.rsc; the platform is detected from the export header.
  • New Level 3 checks for RouterOS 7, tested on CHR 7.25.1: bridge DHCP snooping, bridge ARP inspection (it exists in recent 7.x; older "MikroTik has no DAI" threads are out of date), an 802.1X server on access ports, and no neighbor discovery towards users. Use lyss audit --level 3 router.rsc.
One question for CRS3xx owners: how does /export show storm control on switch ports? Is it set ether2 storm-rate=..., or by port number? CHR has no switch chip, so I couldn't check, and that control stays "unknown" until I know the exact format.
