OpenVPN Client without Username and Password
I’m trying to setup openvpn client on my Mikrotik RB751G but my problem is the vpn provider does not provide user and password authentication.
I have just
CA.crt
Client.crt
Client.key
I did manage to import the certifcates:
And Im trying to setup Client
/interface ovpn-client
add add-default-route=no auth=sha1 certificate=client cipher=blowfish128 connect-to=addres disabled=no name=vpn-to-server profile=OVPN-client
and there is ofc coresponding profile OPEN-client
Why I try to enable this interface im getting error
And the configuration form Windows OpenVPN client that works looks like this:
client
dev tun
proto udp
remote serveradddress.com 1300
cipher AES-256-CBC
resolv-retry infinite
nobind
persist-key
persist-tun
comp-lzo
verb 3
remote-cert-tls server
ping-restart 60
service mullvadopenvpn
ping 10
ca ca.crt
cert client.crt
key client.key
crl-verify crl.pem
tls-cipher TLS-DHE-RSA-WITH-AES-256-CBC-SHA:TLS-DHE-RSA-WITH-CAMELLIA-256-CBC-SHA:TLS-DHE-RSA-WITH-3DES-EDE-CBC-SHA:TLS-DHE-RSA-WITH-AES-128-CBC-SHA:TLS-DHE-RSA-WITH-SEED-CBC-SHA:TLS-DHE-RSA-WITH-CAMELLIA-128-CBC-SHA
If you can help it will be awsome. Thanks in advanced.
Maciek
It is clearly stated in the manual:
http://wiki.mikrotik.com/wiki/Manual:Interface/OVPN
"Currently unsupported OVPN feature:
UDP mode
LZO compression
TLS authentication
authentication without username/password"
My mistake was I did check here http://wiki.mikrotik.com/wiki/OpenVPN and here the list is shorter
Unsupported
UDP
LZO compression
Also since there are features that are not listed in Mikrotik UI and with some scripts possible I thought there could be some work arround.
Thanks anyway,
Cheers,
Maciej
All the features are available in GUI for quite some time now.
What exactly you can set in terminal and can’t do in GUI?
Hello
How i can create files to offer it without username and password in Mikrotik ? to use it in windows client
You can’t.
