Hello! I am trying to setup OpenVPN access on a Microtik hAP ax^3 updated to latest stable version 7.19.2.
When I try to connect, OpenVPN log says:
2025-06-27 15:56:32 VERIFY OK: depth=1, CN=ca.mydomain.ddns.net
2025-06-27 15:56:32 VERIFY KU OK
2025-06-27 15:56:32 Validating certificate extended key usage
2025-06-27 15:56:32 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2025-06-27 15:56:32 VERIFY EKU OK
2025-06-27 15:56:32 VERIFY OK: depth=0, CN=ovpnserver.mydomain.ddns.net
2025-06-27 15:57:32 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2025-06-27 15:57:32 TLS Error: TLS handshake failed
2025-06-27 15:57:32 Fatal TLS error (check_tls_errors_co), restarting
on Mikrotik I configured OpenVPN and opened access on port 1194 (I added rules 2 and 3 on the firewall as follow:)
[admin@MikroTik] > /ip firewall filter print
Flags: X - disabled, I - invalid; D - dynamic
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked
2 chain=input action=accept protocol=tcp in-interface=ether1 dst-port=1194 log=no log-prefix=“”
3 chain=input action=accept protocol=udp in-interface=ether1 dst-port=1194 log=no log-prefix=“”
4 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid
5 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp
6 ;;; defconf: accept to local loopback (for CAPsMAN)
chain=input action=accept dst-address=127.0.0.1
7 ;;; defconf: drop all not coming from LAN
chain=input action=drop in-interface-list=!LAN
8 ;;; defconf: accept in ipsec policy
chain=forward action=accept ipsec-policy=in,ipsec
9 ;;; defconf: accept out ipsec policy
chain=forward action=accept ipsec-policy=out,ipsec
10 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection hw-offload=yes connection-state=established,related
11 ;;; defconf: accept established,related, untracked
chain=forward action=accept connection-state=established,related,untracked
12 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid
13 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
[admin@MikroTik] >
I feel I am still missing something, I’ll be grateful for any help!
