etcnix
September 15, 2014, 10:35am
1
I have a problem with OVPN server on 951G-2HnD, v6.19. The server disconnects all of clients after 1 hour work.
I’ve tested clients on windows (v2.3.3 of openvpn client) and on linux (v2.3.4 of openvpn client).
Configuration of clients:
remote address port
dev tap
proto tcp-client
tls-client
ca ca.crt
auth-user-pass
pull
nobind
persist-key
resolv-retry infinite
script-security 2 system
auth-nocache
auth-user-pass auth.cfg
ping 10
remote-cert-tls server
verb 9
log-append openvpn-client.log
route-method exe
route-delay 2
redirect-gateway def1
OpenVPN settings on RouterBoard:
[admin@tik] > /ppp profile print where name="ovpn"
Flags: * - default
0 name="ovpn" local-address=10.10.10.1 remote-address=ovpn_pool use-mpls=default use-compression=default
use-vj-compression=default use-encryption=default only-one=default change-tcp-mss=default
address-list=""
[admin@tik] > /interface ovpn-server server print
enabled: yes
port: 1194
mode: ethernet
netmask: 24
mac-address: FE:05:DF:70:59:A7
max-mtu: 1500
keepalive-timeout: disabled
default-profile: ovpn
certificate: cert_1
require-client-certificate: no
auth: sha1,md5
cipher: blowfish128,aes128,aes192,aes256
[admin@tik] > /ppp active print
Flags: R - radius
# NAME SERVICE CALLER-ID ADDRESS UPTIME ENCODING
0 u2 ovpn x.x.x.x 10.10.10.10 45m36s BF-128-CBC/SHA1
1 cbtruck ovpn y.y.y.y 10.10.10.12 3m50s BF-128-CBC/SHA1
Hi!
Check Limits settings (Session Timeout) in PPP Profile.
http://gyazo.com/1cebd4a249cc0aaac6ef3fdb88d4bb2c
Regards,
Vitaly
etcnix
September 15, 2014, 2:36pm
3
Thanks for your reply but I’ve already tried to use this option and it’s don’t work with my RouterBoerd
etcnix
September 16, 2014, 10:42am
4
For example I set a parameter of Session Timeout = 2 minutes:
Flags: * - default
0 name="ovpn" local-address=10.10.10.1 remote-address=ovpn_pool session-timeout=2m use-mpls=default
use-compression=default use-vj-compression=default use-encryption=default only-one=default
change-tcp-mss=yes address-list=""
And I get a disconnect after 2 minutes (and message ""terminating… - connect time expired):
10:02:17 ovpn,info,account u2 logged in, 10.10.10.10
10:02:17 ovpn,info <ovpn-u2>: connected
10:04:17 ovpn,info <ovpn-u2>: terminating... - connect time expired
10:04:18 ovpn,info,account u2 logged out, 121 34148 26622 157 118
10:04:18 ovpn,info <ovpn-u2>: disconnected
But when I changed this one in 1 hour 20 minutes I get the disconnect from MikroTik after 1 hour:
Flags: * - default
0 name="ovpn" local-address=10.10.10.1 remote-address=ovpn_pool session-timeout=1h20m use-mpls=default
Log (message “terminating… - internal error”):
12:27:04 ovpn,info,account u2 logged in, 10.10.10.10
12:27:04 ovpn,info <ovpn-u2>: connected
13:28:05 ovpn,info <ovpn-u2>: terminating... - internal error
13:28:06 ovpn,info,account u2 logged out, 3661 299352 307587 3041 2703
13:28:06 ovpn,info <ovpn-u2>: disconnected
What I’m doing wrong?
etcnix
September 18, 2014, 10:20am
5
Guys, any ideas?
May be I have to provide more information?
I need help with this trouble.
patrikg
September 18, 2014, 10:39am
6
Do you use dhcp ??
What lease time of the dhcp ??
etcnix
September 18, 2014, 11:03am
7
I use DHCP only for internal network, not for OVPN.
Lease time is set in 3 days:
patrikg
September 18, 2014, 11:47am
8
I just remember one case, then a loose a connection because of one firewall dropped the dhcp traffic.
Therefor I just wondered if you have some dhcp traffic.
And have you tried to use another time like 1h20m = 80m
etcnix
September 18, 2014, 12:20pm
9
Ok,
I will try setting the time limit like 80m.
etcnix
September 18, 2014, 12:24pm
10
It’s impossible to use a format like 80m.
Only such as: dd hh:mm:ss.
patrikg
September 18, 2014, 12:39pm
11
Okey
Like
Have you tried 01:20:00
etcnix
September 18, 2014, 12:43pm
12
Yes,
In winbox or webfig it can use only like 01:20:00
patrikg
September 18, 2014, 12:57pm
13
And when you print the settings from cli.. the syntax has changed to 1h20m ??? or…
Have you tried to enter the 01:20:00 syntax into the cli ??
The error maybe has something to be with time syntax.
etcnix
September 18, 2014, 1:04pm
14
The syntax like 1h20m displayed in a terminal command line.
mrz
September 18, 2014, 1:32pm
15
Please enable ovpn debug logs, wait until client disconnects, generate supout file and send it tu support[at]mikrotik.com
etcnix
September 18, 2014, 10:23pm
16
Thanks a lot for your reply,
I’ve sent the support file via email.
Zorro
September 20, 2014, 12:37am
17
yeah. aside checking logs, would be important just to sniff/dump traffic both on client computers and MikroTik itself to replicate moment when its happens.
in some ISP’s its misconfigured(sometimes on purpose, but usually due HRM issues)networking gear.
you found “packet sinffer” under “tools” portion of RouterOS. due to predictible size of dump for one hour session, you had to stream it somewhere outside MikroTik.
shed
September 20, 2014, 11:49pm
18
Add option under…
–reneg-sec 0
–reneg-sec n : Renegotiate data chan. key after n seconds (default=3600).
etcnix
September 22, 2014, 8:10am
19
Thanks a lot, shed!
The problem was solved. I added this option on the client’s sides and it helped me.
