OpenVPN on RC13
Just tested the open VPN feature once again.
OK with the help of the wiki I got it up and running.
Now the config example in the wiki uses the username/password
authentication. Since the openvpn client on windows can’t use
a auth.cfg file (i have no means of recompiling on windows)
i will be prompted for username and password on
every login.
Is there a way to configure authentication based on certificates
only? This would provide a way for a ovpn connection from a windows
client without user intervention.
Ekkehard
Im having a similar problem over here…
Need to be able to set up a MT running openvpn client to connect to a Unix based server using ONLY certificates.
No username & Password.
Currently i get error if i don’t type in a username!
Please help Someone!
