Hi, I am trying to connect OpenVPN in Windows but seems like it has an issue with cipher. I attached all the information and screenshots below.
client.ovpn
client
dev tun
remote x.x.x.x 1194 tcp
tun-mtu 1500
tls-client
nobind
user nobody
group nogroup
ping 15
ping-restart 45
ping-timer-rem
persist-tun
persist-key
mute-replay-warnings
verb 4
cipher AES-256-GCM
auth SHA1
pull
auth-user-pass
connect-retry 1
reneg-sec 3600
remote-cert-tls server
<ca>
-----BEGIN CERTIFICATE-----
xxxxxxxxx
-----END CERTIFICATE-----
</ca>
<cert>
xxxxxxxxxx
</cert>
<key>
-----BEGIN ENCRYPTED PRIVATE KEY-----
xxxxxxxxxxx
-----END ENCRYPTED PRIVATE KEY-----
</key>
I tried cipher AES-256-GCM, CBC, but none of them worked. I tried to set auth mode to null, sha1, but neither of them worked.
BUT,
Same with the same configuration in RouterOS 7 worked perfectly just there is “aes-256-gcm” in the OpenVPN server config, but not in ROS 6.
Please, if anyone has a solution for this, let me know.
I appreciate any kind of suggestions.
Thanks for reading!
Chillout
