OPSF loop
Hello everyone,
I stumbled accross a weird routing behaviour on my network.
In general my network is:
Mikrotik CCR2004 as internet & VPN router connected to 2x OPNsense which are connected to a Mikrotik CCR2116 as my network router.
As a failover my CCR2004 is also direct to CCR2116 but with higher costs so any traffic would go through my firewall.
Anytime I modify an OSPF setting on OPNsense and reload the process it gets reconnected but no traffic is going through it - it becomes unreachable.
Both Mikrotik routers show that OSPF is connected and exchanged all information (State = Full).
I connected to an OPNsense VM to see what is happending there and FRRs vtysh also show that it’s fully exchanged on I can see all routes.
Only ICMP and traceroute is not working:
PING k8s-1.hks.lan (10.0.22.80): 56 data bytes
92 bytes from 172.16.1.2: Time to live exceeded
Vr HL TOS  Len   ID Flg  off TTL Pro  cks      Src      Dst
 4  5  00 0054 b660   0 0000  01  01 35e7 172.16.1.2  10.0.22.80
 4  5  00 0054 ef8c   0 0000  01  01 fcba 172.16.1.2  10.0.22.80
 4  5  00 0054 cbe3   0 0000  01  01 2064 172.16.1.2  10.0.22.80
Traceroute is running between Mikrotik and CCR2116 - I guess until TTL is reached and is then been kicked.
Currently the only solution is to restart CCR2116 to get everything running again.
Is there a bug somewhere?
I think I fixed it by setting different costs for interface pointing to CCR2004 and CCR2116
