I have a little problem here. Could somebody help me?
I have network of mikrotik routers. I use OSPF for dynamic routing and so far I had only backbone area. But now I wish to create another Becouse the routing table grows bigger and bigger. But even if I have different area, routes from that area are still distributed to another routers. I tried to setup “area range” on border router but it didn’t help. It added the “area route” but the other routes are there also.
Router in the backbone area:
/ routing ospf
set router-id=0.0.0.0 distribute-default=never \
redistribute-connected=as-type-1 redistribute-static=as-type-1 \
redistribute-rip=no redistribute-bgp=no metric-default=1 \
metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=20
/ routing ospf area
set backbone area-id=0.0.0.0 type=default translator-role=translate-candidate \
authentication=none disabled=no
/ routing ospf interface
set FIXME interface=all cost=10 priority=1 authentication-key="" \
network-type=broadcast retransmit-interval=5s transmit-delay=1s \
hello-interval=10s dead-interval=40s
set FIXME interface="ether1->LUKAS DOMA-CIS 5GNET SMRKOVICE" cost=10 \
priority=1 authentication-key="" network-type=broadcast \
retransmit-interval=5s transmit-delay=1s hello-interval=10s \
dead-interval=40s
/ routing ospf network
add network=10.11.5.44/30 area=backbone disabled=no
add network=10.11.150.0/24 area=backbone disabled=no
border router:
/ routing ospf
set router-id=10.200.1.1 distribute-default=never redistribute-connected=no \
redistribute-static=no redistribute-rip=no redistribute-bgp=no \
metric-default=1 metric-connected=20 metric-static=20 metric-rip=20 \
metric-bgp=20
/ routing ospf area
add name="lukas" area-id=10.200.0.0 type=default \
translator-role=translate-never authentication=md5 default-cost=1 \
disabled=no
/ routing ospf area range
add area=lukas range=10.200.0.0/16 cost=default advertise=yes disabled=no
set FIXME interface=LAN-integrovana cost=10 priority=1 \
authentication-key="doma" network-type=broadcast retransmit-interval=5s \
transmit-delay=1s hello-interval=10s dead-interval=40s
set FIXME interface=WAN-pci cost=10 priority=1 authentication-key="" \
add network=10.200.1.0/24 area=lukas disabled=no
router in the “lukas” area:
/ routing ospf
/ routing ospf area
disabled=no
set FIXME interface=CLI cost=10 priority=1 authentication-key="doma" \
set FIXME interface=RASIN->CEREKVICE cost=10 priority=1 \
authentication-key="cere--kvice" network-type=point-to-point \
dead-interval=40s
add network=10.200.5.36/30 area=lukas disabled=no
add network=10.200.5.40/30 area=lukas disabled=no
Thanks for helping.
